주요 콘텐츠로 건너뛰기
Lenovo ThinkPad X1 Carbon 9th Gen Battery Replacement
필요한 것
  1. Lenovo ThinkPad X1 Carbon 9th Gen Battery Replacement, Unfasten the back cover: 1 단계, 이미지 1/2 Lenovo ThinkPad X1 Carbon 9th Gen Battery Replacement, Unfasten the back cover: 1 단계, 이미지 2/2
    • For your safety, discharge the battery below 25% and power down your device before disassembly.
    • Use a Phillips #1 screwdriver to loosen the five captive screws holding the back cover.
  2. Lenovo ThinkPad X1 Carbon 9th Gen Battery Replacement, Release the corner clips: 2 단계, 이미지 1/2 Lenovo ThinkPad X1 Carbon 9th Gen Battery Replacement, Release the corner clips: 2 단계, 이미지 2/2
    • Insert an opening pick between a corner of the back cover and the chassis, near a hinge.
    • Pry upward to release the retaining clips.
    • Listen for a click sound when clips release.
    • Repeat this process for the opposite corner.
  3. Lenovo ThinkPad X1 Carbon 9th Gen Battery Replacement, Release the edge clips: 3 단계, 이미지 1/2 Lenovo ThinkPad X1 Carbon 9th Gen Battery Replacement, Release the edge clips: 3 단계, 이미지 2/2
    • Insert the opening pick between the cover and the body.
    • Pry upward and release all of the retaining clips.
  4. Lenovo ThinkPad X1 Carbon 9th Gen Battery Replacement, Remove the back cover: 4 단계, 이미지 1/2 Lenovo ThinkPad X1 Carbon 9th Gen Battery Replacement, Remove the back cover: 4 단계, 이미지 2/2
    • Lift the back cover off the chassis and remove it.
    • If the cover feels stuck to the chassis, use an opening pick to release any remaining clips around the perimeter of the back cover.
  5. Lenovo ThinkPad X1 Carbon 9th Gen Battery Replacement, Unfasten the battery: 5 단계, 이미지 1/2 Lenovo ThinkPad X1 Carbon 9th Gen Battery Replacement, Unfasten the battery: 5 단계, 이미지 2/2
    • Use a Phillips #1 screwdriver to remove the six 4.9 mm screws securing the battery to the laptop chassis.
  6. Lenovo ThinkPad X1 Carbon 9th Gen Battery Replacement, Remove the battery: 6 단계, 이미지 1/3 Lenovo ThinkPad X1 Carbon 9th Gen Battery Replacement, Remove the battery: 6 단계, 이미지 2/3 Lenovo ThinkPad X1 Carbon 9th Gen Battery Replacement, Remove the battery: 6 단계, 이미지 3/3
    • Grip the corners of the battery.
    • Pull and lift the battery of its recess and remove it.
    • Be delicate when pulling the battery out at first. The small pins on its connector are easy to bend.
    • There is no cable for the battery. It disconnects when removed from its recess.
결론
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Lenovo ThinkPad X1 Carbon community for help.
Clay Eickemeyer
회원 가입일: 09/19/22
66,992 평판
안내서 453개 작성하였습니다
iFixit iFixit 회원
Staff
136 회원들
안내서 17,299개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 17
7일 전: 96
30일 전: 445
전체 시간: 4,678
