주요 콘텐츠로 건너뛰기
Lenovo ThinkPad X1 Extreme Camera Replacement
필요한 것
  1. Lenovo ThinkPad X1 Extreme Camera Replacement, Back Cover: 1 단계, 이미지 1/3 Lenovo ThinkPad X1 Extreme Camera Replacement, Back Cover: 1 단계, 이미지 2/3 Lenovo ThinkPad X1 Extreme Camera Replacement, Back Cover: 1 단계, 이미지 3/3
    • Power off and unplug your device before you begin.
    • Orient the laptop so that it is bottom up, and the trackpad is closest to you.
    • Unscrew the seven captive screws with a Phillips #00 screwdriver.
    • These screws will loosen, but stay attached to the cover. Do not attempt to completely remove them.
    • Slide a blue opening pick in the gap between the bottom panel and chassis, and pry off the one clip on each side.
    • Remove the back cover from the device.
  2. Lenovo ThinkPad X1 Extreme Camera Replacement, Speakers: 2 단계, 이미지 1/1
    • Use a Phillips #00 head screwdriver to remove the four 4 mm screws above the battery.
  3. Lenovo ThinkPad X1 Extreme Camera Replacement: 3 단계, 이미지 1/1
    • Lift the speaker modules on either side of the battery out of its pegs, and unwind the cable from the front of the battery.
    • Set the speaker modules out of the way.
  4. Lenovo ThinkPad X1 Extreme Camera Replacement, Battery: 4 단계, 이미지 1/3 Lenovo ThinkPad X1 Extreme Camera Replacement, Battery: 4 단계, 이미지 2/3 Lenovo ThinkPad X1 Extreme Camera Replacement, Battery: 4 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Use tweezers to peel the plastic cover off the connector.
    • Use a spudger or your fingernail to pry up the battery straight up from the motherboard.
  5. Lenovo ThinkPad X1 Extreme Camera Replacement: 5 단계, 이미지 1/1
    • Lift the battery out of the frame and remove it from the device.
  6. Lenovo ThinkPad X1 Extreme Camera Replacement, Display: 6 단계, 이미지 1/2 Lenovo ThinkPad X1 Extreme Camera Replacement, Display: 6 단계, 이미지 2/2
    • Gently take off the cover of the hinge of the computer with a combination of the opening tool and your hands.
  7. Lenovo ThinkPad X1 Extreme Camera Replacement: 7 단계, 이미지 1/1
    • Lift up the covering of the display using the opening tool.
  8. Lenovo ThinkPad X1 Extreme Camera Replacement: 8 단계, 이미지 1/1
    • Use a spudger to release the retaining flap on the cable connector.
  9. Lenovo ThinkPad X1 Extreme Camera Replacement: 9 단계, 이미지 1/2 Lenovo ThinkPad X1 Extreme Camera Replacement: 9 단계, 이미지 2/2
    • Pull the wire that was connected to the retaining flap through the hinge.
    • Remove the display from the laptop.
  10. Lenovo ThinkPad X1 Extreme Camera Replacement, Camera: 10 단계, 이미지 1/2 Lenovo ThinkPad X1 Extreme Camera Replacement, Camera: 10 단계, 이미지 2/2
    • Detach the wire that's connected to the camera.
    • Remove the camera.
결론
Yeungchin Darren Chan
회원 가입일: 02/10/22
73 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 30
전체 시간: 666
