주요 콘텐츠로 건너뛰기
Lenovo ThinkPad X1 Extreme Charging Port Replacement
필요한 것
  1. Lenovo ThinkPad X1 Extreme Charging Port Replacement, Back Cover: 1 단계, 이미지 3개 중 1개 Lenovo ThinkPad X1 Extreme Charging Port Replacement, Back Cover: 1 단계, 이미지 3개 중 2개 Lenovo ThinkPad X1 Extreme Charging Port Replacement, Back Cover: 1 단계, 이미지 3개 중 3개
    • Power off and unplug your device before you begin.
    • Orient the laptop so that it is bottom up, and the trackpad is closest to you.
    • Unscrew the seven captive screws with a Phillips #00 screwdriver.
    • These screws will loosen, but stay attached to the cover. Do not attempt to completely remove them.
    • Slide a blue opening pick in the gap between the bottom panel and chassis, and pry off the one clip on each side.
    • Remove the back cover from the device.
  2. Lenovo ThinkPad X1 Extreme Charging Port Replacement, Fan: 2 단계, 이미지 3개 중 1개 Lenovo ThinkPad X1 Extreme Charging Port Replacement, Fan: 2 단계, 이미지 3개 중 2개 Lenovo ThinkPad X1 Extreme Charging Port Replacement, Fan: 2 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    Phillips #00 Screwdriver
    $5.49
    • Unscrew the 3mm screw holding down the wireless adapter using a Phillips #00 screwdriver.
    • Slide the adapter out of its connector.
    • Detach the black and gray cables and separate them from the frame of the fan by gently pulling upwards.
  3. Lenovo ThinkPad X1 Extreme Charging Port Replacement: 3 단계, 이미지 2개 중 1개 Lenovo ThinkPad X1 Extreme Charging Port Replacement: 3 단계, 이미지 2개 중 2개
    • Unlatch and remove the cable connecting to the frame of the fan by flipping the thin black tab up.
    • Separate the cable from the frame of the fan.
  4. Lenovo ThinkPad X1 Extreme Charging Port Replacement: 4 단계, 이미지 2개 중 1개 Lenovo ThinkPad X1 Extreme Charging Port Replacement: 4 단계, 이미지 2개 중 2개
    • Loosen the five screws connecting the fan to the motherboard using a Philips #00 head screwdriver.
    • These screws will not come out and will stay connected to the fan.
  5. Lenovo ThinkPad X1 Extreme Charging Port Replacement: 5 단계, 이미지 3개 중 1개 Lenovo ThinkPad X1 Extreme Charging Port Replacement: 5 단계, 이미지 3개 중 2개 Lenovo ThinkPad X1 Extreme Charging Port Replacement: 5 단계, 이미지 3개 중 3개
    • Gently disconnect the two cables located on right and left side of the fan.
    • To identify these, they are labeled "FANR1" and FANL2" on the motherboard.
    • Lift the fan up and out and remove it from the device.
  6. Lenovo ThinkPad X1 Extreme Charging Port Replacement, Charging Port: 6 단계, 이미지 1개 중 1개
    • Using the Phillips #00 screwdriver, remove the two screws on the cover of the charging port.
  7. Lenovo ThinkPad X1 Extreme Charging Port Replacement: 7 단계, 이미지 2개 중 1개 Lenovo ThinkPad X1 Extreme Charging Port Replacement: 7 단계, 이미지 2개 중 2개
    • Disconnect the charging port cable from the motherboard.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 9
지난 30일: 39
전체 시간: 2,675
