주요 콘텐츠로 건너뛰기
Lenovo ThinkPad X1 Extreme RAM Replacement
필요한 것
  1. Lenovo ThinkPad X1 Extreme RAM Replacement, Back Cover: 1 단계, 이미지 1/3 Lenovo ThinkPad X1 Extreme RAM Replacement, Back Cover: 1 단계, 이미지 2/3 Lenovo ThinkPad X1 Extreme RAM Replacement, Back Cover: 1 단계, 이미지 3/3
    • Power off and unplug your device before you begin.
    • Orient the laptop so that it is bottom up, and the trackpad is closest to you.
    • Unscrew the seven captive screws with a Phillips #00 screwdriver.
    • These screws will loosen, but stay attached to the cover. Do not attempt to completely remove them.
    • Slide a blue opening pick in the gap between the bottom panel and chassis, and pry off the one clip on each side.
    • Remove the back cover from the device.
  2. Lenovo ThinkPad X1 Extreme RAM Replacement, RAM: 2 단계, 이미지 1/1
    • Use an opening tool to unlatch the silver gate on the side of the RAM by pushing it away from the component.
    • Repeat the same process to the other side of the RAM.
  3. Lenovo ThinkPad X1 Extreme RAM Replacement: 3 단계, 이미지 1/1
    • Gently grab the RAM and slide it up and away from the connector at the bottom of the component.
결론
Addy Botao Liu
회원 가입일: 02/21/21
265 평판
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 26
전체 시간: 1,025
