주요 콘텐츠로 건너뛰기
Lenovo ThinkPad X1 Extreme SSD Replacement
필요한 것
  1. Lenovo ThinkPad X1 Extreme SSD Replacement, Back Cover: 1 단계, 이미지 3개 중 1개 Lenovo ThinkPad X1 Extreme SSD Replacement, Back Cover: 1 단계, 이미지 3개 중 2개 Lenovo ThinkPad X1 Extreme SSD Replacement, Back Cover: 1 단계, 이미지 3개 중 3개
    • Power off and unplug your device before you begin.
    • Orient the laptop so that it is bottom up, and the trackpad is closest to you.
    • Unscrew the seven captive screws with a Phillips #00 screwdriver.
    • These screws will loosen, but stay attached to the cover. Do not attempt to completely remove them.
    • Slide a blue opening pick in the gap between the bottom panel and chassis, and pry off the one clip on each side.
    • Remove the back cover from the device.
  2. Lenovo ThinkPad X1 Extreme SSD Replacement, SSD: 2 단계, 이미지 2개 중 1개 Lenovo ThinkPad X1 Extreme SSD Replacement, SSD: 2 단계, 이미지 2개 중 2개
    • Using the Phillips #00 screwdriver, remove the single screw securing the SSD to the motherboard.
  3. Lenovo ThinkPad X1 Extreme SSD Replacement: 3 단계, 이미지 2개 중 1개 Lenovo ThinkPad X1 Extreme SSD Replacement: 3 단계, 이미지 2개 중 2개
    • Using the opening tool, pop out the SSD card and remove it from the device.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
1가이드 댓글
Anyhow this laptop support gen 4 nvme or higher?
jordan chong - 답글
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 16
지난 30일: 58
전체 시간: 2,714
