주요 콘텐츠로 건너뛰기
Lenovo ThinkPad X1 Yoga (3rd Gen) SSD Replacement
필요한 것
  1. Lenovo ThinkPad X1 Yoga (3rd Gen) SSD Replacement, SSD: 1 단계, 이미지 1/1
    • Restart your laptop.
    • Press the "Enter" key repeatedly. This will bring you to the BIOS.
    • Your laptop should not be plugged in, or charging, for the next steps.
  2. Lenovo ThinkPad X1 Yoga (3rd Gen) SSD Replacement: 2 단계, 이미지 1/2 Lenovo ThinkPad X1 Yoga (3rd Gen) SSD Replacement: 2 단계, 이미지 2/2
    • Use the left and right arrow keys to navigate to the Config section of the BIOS.
    • From the Config section, use the up and down arrow keys to navigate to the Disable Built-in Battery option.
    • Hit the "Enter" key twice to proceed.
    • The battery will now be temporarily disabled, allowing you to safely complete the next steps. To power on your laptop, it must now be plugged in to a charger.
  3. Lenovo ThinkPad X1 Yoga (3rd Gen) SSD Replacement: 3 단계, 이미지 1/3 Lenovo ThinkPad X1 Yoga (3rd Gen) SSD Replacement: 3 단계, 이미지 2/3 Lenovo ThinkPad X1 Yoga (3rd Gen) SSD Replacement: 3 단계, 이미지 3/3
    • Remove the eight 2 mm-long Philips #00 screws on the lower case.
    • These screws are self-contained in the backplate.
  4. Lenovo ThinkPad X1 Yoga (3rd Gen) SSD Replacement: 4 단계, 이미지 1/3 Lenovo ThinkPad X1 Yoga (3rd Gen) SSD Replacement: 4 단계, 이미지 2/3 Lenovo ThinkPad X1 Yoga (3rd Gen) SSD Replacement: 4 단계, 이미지 3/3
    • Pry the backplate cover away from the laptop using your hands.
    • If you have access to a prying tool, you may use one.
    • Do not bend the backplate. With the screws loosened from the previous step, this panel can be removed with only a little effort.
    • Grasp the plastic shield with your hand and pull it away from the laptop.
    • This will reveal the M.2 slot, where your SSD is installed.
  5. Lenovo ThinkPad X1 Yoga (3rd Gen) SSD Replacement: 5 단계, 이미지 1/3 Lenovo ThinkPad X1 Yoga (3rd Gen) SSD Replacement: 5 단계, 이미지 2/3 Lenovo ThinkPad X1 Yoga (3rd Gen) SSD Replacement: 5 단계, 이미지 3/3
    • Remove the 2.8 mm-long Philips #00 screw located in the M.2 slot.
    • Do not lose this screw! It must be reused later.
    • Gently grasp the SSD from where the screw was located.
    • Pull the SSD to remove it from the M.2 slot. If the SSD does not immediately release, gently wiggle it while pulling.
    • Once you have removed the old hard drive, pull it out of the plastic heatshield.
    • This heatshield will be reused with your new hard drive.
  6. Lenovo ThinkPad X1 Yoga (3rd Gen) SSD Replacement: 6 단계, 이미지 1/2 Lenovo ThinkPad X1 Yoga (3rd Gen) SSD Replacement: 6 단계, 이미지 2/2
    • Push the new SSD into the plastic heatshield. It should fit snugly.
    • Insert the new SSD into the M.2 socket.
    • Screw in the 2.8 mm-long Philips #00 screw to complete installation.
결론
To reassemble your device, follow these instructions in reverse order. Once your laptop is assembled, plug in the laptop to turn it on.
다른 한 분이 해당 안내서를 완성하였습니다.
Nicholas Clauser
회원 가입일: 09/19/23
163 평판
안내서 1개 작성함
York University, Team B-20, Woodhouse Fall 2023 York University, Team B-20, Woodhouse Fall 2023 회원
YORK-WOODHOUSE-F23SBG20
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 14
30일 전: 107
전체 시간: 658
