주요 콘텐츠로 건너뛰기
Lenovo ThinkPad X1 Yoga (5th Gen) Thermal Paste Replacement
필요한 것
  1. Lenovo ThinkPad X1 Yoga (5th Gen) Thermal Paste Replacement, Opening the back panel: 1 단계, 이미지 1/2 Lenovo ThinkPad X1 Yoga (5th Gen) Thermal Paste Replacement, Opening the back panel: 1 단계, 이미지 2/2
    • Unscrew all screws holding the back panel in place.
    • Use a prying tool to release all the clips and remove the panel.
  2. Lenovo ThinkPad X1 Yoga (5th Gen) Thermal Paste Replacement, Changing the thermal paste: 2 단계, 이미지 1/3 Lenovo ThinkPad X1 Yoga (5th Gen) Thermal Paste Replacement, Changing the thermal paste: 2 단계, 이미지 2/3 Lenovo ThinkPad X1 Yoga (5th Gen) Thermal Paste Replacement, Changing the thermal paste: 2 단계, 이미지 3/3
    • It is recommended to disconnect the battery.
    • Unscrew the 4 screws holding the CPU heatsink and disconnect the fan.
    • Clean the old thermal paste both from the cooler and the CPU. It is best to use isopropyl alcohol and cotton swabs or paper towel, but be careful not to go too hard on the CPU.
    • It is also recommended to use compressed air to remove any dust in the laptop and the fan. You can also open it to clean it from the inside.
    • Dont use too much thermal paste, just enough to cover some portion of the pad. If you have a spreader, use it. The thermal paste will apply evenly after you tighten the heatsink.
    • Last, put the heatsink back carefully and tighten the screws in order 1 -> 4 to ensure even pressure. Dont forget to plug in the fan cable.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Simeon Brankov
회원 가입일: 11/08/20
6,502 평판
안내서 51개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 15
30일 전: 65
전체 시간: 1,074
