필요한 것
Use a Phillips #1 screwdriver to remove the five 5 mm screws that secure the base panel.
Wedge a spudger between the base panel and chassis, and pry around the entire perimeter until you hear a pop and the base panel releases.
Lift the base panel up and off of the chassis.
Use a Phillips #1 screwdriver to remove the five 4.5 mm screws securing the battery.
Lift the battery up and out.
Use a spudger to pry the coin cell battery until it releases from the chassis.
Use the spudger to lift the flap covering the speaker wire.
Starting at the top of the right speaker, follow the wire connected to the top of the left speaker. Use the tip of a spudger to free the wire from the plastic brackets it lies under.
Starting from near the bottom-left side of the right speaker, follow the lower wire, unseating the speaker cable as you go.
Use a Phillips #1 screwdriver to remove the two 5.0 mm screws that secure the headphone jack.
Use tweezers to lift the headphone jack to the right to free it from the chassis.
Use a Phillips #1 screwdriver to remove the nine 3.2 mm screws from the motherboard.
Use a plastic spudger to lift the flaps covering the pins. Disconnect the pins from the motherboard.
Use a plastic spudger to disconnect the two wires connected to the CPU.
Use a plastic spudger to disconnect the pin on the bottom left of the motherboard.
Use a Phillips #1 screwdriver to remove the two 3.2mm screws securing the stylus.
Use a Phillips #1 screwdriver to remove the one 4.0mm screws securing the stylus.
Lift the stylus out of the chassis.
