주요 콘텐츠로 건너뛰기
Lenovo ThinkPad X1 Yoga (6th Gen) SSD Replacement
필요한 것
  1. Lenovo ThinkPad X1 Yoga (6th Gen) SSD Replacement, Base Panel: 1 단계, 이미지 1/3 Lenovo ThinkPad X1 Yoga (6th Gen) SSD Replacement, Base Panel: 1 단계, 이미지 2/3 Lenovo ThinkPad X1 Yoga (6th Gen) SSD Replacement, Base Panel: 1 단계, 이미지 3/3
    • Use a Phillips #1 screwdriver to remove the five 5 mm screws that secure the base panel.
    • Wedge a spudger between the base panel and chassis, and pry around the entire perimeter until you hear a pop and the base panel releases.
    • Lift the base panel up and off of the chassis.
  2. Lenovo ThinkPad X1 Yoga (6th Gen) SSD Replacement, SSD: 2 단계, 이미지 1/3 Lenovo ThinkPad X1 Yoga (6th Gen) SSD Replacement, SSD: 2 단계, 이미지 2/3 Lenovo ThinkPad X1 Yoga (6th Gen) SSD Replacement, SSD: 2 단계, 이미지 3/3
    • Use a Phillips #1 screwdriver to remove the two 2.2 mm screws securing the copper plate over the SSD.
    • Lift the copper plate up and out.
  3. Lenovo ThinkPad X1 Yoga (6th Gen) SSD Replacement: 3 단계, 이미지 1/1
    • Gently lift up on the left side of the SSD, then pull it to the left to remove it from its socket.
결론
Taylor Morgan
회원 가입일: 02/15/22
521 평판
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 11
30일 전: 52
전체 시간: 1,130
