주요 콘텐츠로 건너뛰기
Lenovo ThinkPad X1 Yoga (6th Gen) Speaker Replacement
필요한 것
  1. Lenovo ThinkPad X1 Yoga (6th Gen) Speaker Replacement, Base Panel: 1 단계, 이미지 1/3 Lenovo ThinkPad X1 Yoga (6th Gen) Speaker Replacement, Base Panel: 1 단계, 이미지 2/3 Lenovo ThinkPad X1 Yoga (6th Gen) Speaker Replacement, Base Panel: 1 단계, 이미지 3/3
    • Use a Phillips #1 screwdriver to remove the five 5 mm screws that secure the base panel.
    • Wedge a spudger between the base panel and chassis, and pry around the entire perimeter until you hear a pop and the base panel releases.
    • Lift the base panel up and off of the chassis.
  2. Lenovo ThinkPad X1 Yoga (6th Gen) Speaker Replacement, Battery: 2 단계, 이미지 1/3 Lenovo ThinkPad X1 Yoga (6th Gen) Speaker Replacement, Battery: 2 단계, 이미지 2/3 Lenovo ThinkPad X1 Yoga (6th Gen) Speaker Replacement, Battery: 2 단계, 이미지 3/3
    • Use a Phillips #1 screwdriver to remove the five 4.5 mm screws securing the battery.
    • Lift the battery up and out.
  3. Lenovo ThinkPad X1 Yoga (6th Gen) Speaker Replacement, Speaker: 3 단계, 이미지 1/3 Lenovo ThinkPad X1 Yoga (6th Gen) Speaker Replacement, Speaker: 3 단계, 이미지 2/3 Lenovo ThinkPad X1 Yoga (6th Gen) Speaker Replacement, Speaker: 3 단계, 이미지 3/3
    • Use a Phillips #1 screwdriver to remove the four 1.8 mm screws.
  4. Lenovo ThinkPad X1 Yoga (6th Gen) Speaker Replacement: 4 단계, 이미지 1/3 Lenovo ThinkPad X1 Yoga (6th Gen) Speaker Replacement: 4 단계, 이미지 2/3 Lenovo ThinkPad X1 Yoga (6th Gen) Speaker Replacement: 4 단계, 이미지 3/3
    • Use the spudger to lift the flap covering the speaker wire.
    • Starting at the top of the right speaker, follow the wire connected to the top of the left speaker. Use the tip of a spudger to free the wire from the plastic brackets it lies under.
    • Starting from near the bottom-left side of the right speaker, follow the lower wire, unseating the speaker cable as you go.
  5. Lenovo ThinkPad X1 Yoga (6th Gen) Speaker Replacement: 5 단계, 이미지 1/3 Lenovo ThinkPad X1 Yoga (6th Gen) Speaker Replacement: 5 단계, 이미지 2/3 Lenovo ThinkPad X1 Yoga (6th Gen) Speaker Replacement: 5 단계, 이미지 3/3
    • Place your fingernails behind each of the plastic tabs on the speaker's plug and pull directly backwards until the plug releases from its port.
    • Lift the speakers up and out.
결론
Taylor Morgan
회원 가입일: 02/15/22
521 평판
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 18
전체 시간: 401
