주요 콘텐츠로 건너뛰기
Lenovo ThinkPad X1 Yoga 2nd Generation Fan Replacement
필요한 것
  1. Lenovo ThinkPad X1 Yoga 2nd Generation Fan Replacement, Back Cover: 1 단계, 이미지 1/1
    • Ensure the laptop is powered off and the charging cable is disconnected before opening the back cover.
    • Flip over the laptop to access the back cover.
  2. Lenovo ThinkPad X1 Yoga 2nd Generation Fan Replacement: 2 단계, 이미지 1/2 Lenovo ThinkPad X1 Yoga 2nd Generation Fan Replacement: 2 단계, 이미지 2/2
    • Use a Phillips #0 screwdriver to remove the eight 8 mm screws.
  3. Lenovo ThinkPad X1 Yoga 2nd Generation Fan Replacement: 3 단계, 이미지 1/1
    • Remove the back cover.
    • A popping sound may occur when the back cover is removed.
  4. Lenovo ThinkPad X1 Yoga 2nd Generation Fan Replacement, Fan: 4 단계, 이미지 1/2 Lenovo ThinkPad X1 Yoga 2nd Generation Fan Replacement, Fan: 4 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Lift up the small, metal tab using a spudger.
    • Do not use the metal spudger unless if it's being used for serious prying power. The metal spudger may damage or puncture internal components in the device if too much pressure is applied.
    • Gently lift the ribbon cable from its socket using nylon-tipped reverse tweezers.
  5. Lenovo ThinkPad X1 Yoga 2nd Generation Fan Replacement: 5 단계, 이미지 1/1
    • Using the Phillips #0 screwdriver, unscrew the four 4 mm screws directly next to the fan.
  6. Lenovo ThinkPad X1 Yoga 2nd Generation Fan Replacement: 6 단계, 이미지 1/2 Lenovo ThinkPad X1 Yoga 2nd Generation Fan Replacement: 6 단계, 이미지 2/2
    • Loosen the four 5 mm screws in the metal extension attached to the fan.
    • The screws do not need to be completely removed from the fan.
    • Remove the fan using your fingers.
결론
Alex Shacoski
회원 가입일: 02/10/20
270 평판
안내서 2개 작성하였습니다
Cal Poly, Team S22-G3, Regan Winter 2020 Cal Poly, Team S22-G3, Regan Winter 2020 회원
CPSU-REGAN-W20S22G3
5 회원들
안내서 7개 작성하였습니다
댓글 3개
When you remove a heasink (or heat transfer pipe) from a chip, shouldn't you re-apply any thermal paste? Surely it had some?
Edward Dekkers - 답글
after pressing power button Cooling fan runs for 2 sec then it stays off . What is the problem ?
Tonmoy Arafin - 답글
Is there any upgrade that one can do to the fan or pipe except new thermal paste? I find it quite loud and inefficient. Isn't there a third-party one which is quieter?
Oliver - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 6
30일 전: 30
전체 시간: 938
