주요 콘텐츠로 건너뛰기
Lenovo ThinkPad X1 Yoga 2nd Generation Trackpad Replacement
필요한 것
  1. Lenovo ThinkPad X1 Yoga 2nd Generation Trackpad Replacement, Back Cover: 1 단계, 이미지 1/1
    • Ensure the laptop is powered off and the charging cable is disconnected before opening the back cover.
    • Flip over the laptop to access the back cover.
  2. Lenovo ThinkPad X1 Yoga 2nd Generation Trackpad Replacement: 2 단계, 이미지 1/2 Lenovo ThinkPad X1 Yoga 2nd Generation Trackpad Replacement: 2 단계, 이미지 2/2
    • Use a Phillips #0 screwdriver to remove the eight 8 mm screws.
  3. Lenovo ThinkPad X1 Yoga 2nd Generation Trackpad Replacement: 3 단계, 이미지 1/1
    • Remove the back cover.
    • A popping sound may occur when the back cover is removed.
  4. Lenovo ThinkPad X1 Yoga 2nd Generation Trackpad Replacement, Speakers: 4 단계, 이미지 1/2 Lenovo ThinkPad X1 Yoga 2nd Generation Trackpad Replacement, Speakers: 4 단계, 이미지 2/2
    이 단계에 사용된 도구:
    $3.99
    구매
    • Follow the ribbon cable that runs from the left speaker to the motherboard.
    • Pull the black connector up and release the cable wire by hand.
    • If needed, pull this connector up using the Pro/ESD/angled tweezers.
  5. Lenovo ThinkPad X1 Yoga 2nd Generation Trackpad Replacement: 5 단계, 이미지 1/2 Lenovo ThinkPad X1 Yoga 2nd Generation Trackpad Replacement: 5 단계, 이미지 2/2
    • Remove two 6 mm Phillips #0 screws from each speaker.
  6. Lenovo ThinkPad X1 Yoga 2nd Generation Trackpad Replacement: 6 단계, 이미지 1/2 Lenovo ThinkPad X1 Yoga 2nd Generation Trackpad Replacement: 6 단계, 이미지 2/2
    • Use your fingers to remove the speakers from the device.
  7. Lenovo ThinkPad X1 Yoga 2nd Generation Trackpad Replacement, Battery: 7 단계, 이미지 1/1
    • Use a spudger to pop the ribbon cable that runs from the upper-middle portion of the battery to the motherboard out of the motherboard.
    • Do not use a metal spudger as indicated in the photos. The metal spudger should only be used for serious prying power. If it's used on the internal components of a device, it may puncture or damage the components in your device.
  8. Lenovo ThinkPad X1 Yoga 2nd Generation Trackpad Replacement: 8 단계, 이미지 1/1
    • Use a Phillips #0 screwdriver to remove one 6 mm screw from the bottom-middle portion of the battery.
  9. Lenovo ThinkPad X1 Yoga 2nd Generation Trackpad Replacement: 9 단계, 이미지 1/1
    • Remove the battery.
  10. Lenovo ThinkPad X1 Yoga 2nd Generation Trackpad Replacement, Trackpad: 10 단계, 이미지 1/2 Lenovo ThinkPad X1 Yoga 2nd Generation Trackpad Replacement, Trackpad: 10 단계, 이미지 2/2
    • Using a Phillips #0 screwdriver, remove four 3 mm screws.
  11. Lenovo ThinkPad X1 Yoga 2nd Generation Trackpad Replacement: 11 단계, 이미지 1/1
    • Lift up the laptop and remove the trackpad from the device.
    • When you lift up the bottom panel, the trackpad should fall from the device.
결론
Luke James Wiggins
회원 가입일: 02/22/21
85 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 9
전체 시간: 529
