주요 콘텐츠로 건너뛰기
Lenovo ThinkPad X1 Yoga Hard Drive Replacement
필요한 것
  1. Lenovo ThinkPad X1 Yoga Hard Drive Replacement, Back Cover: 1 단계, 이미지 1/3 Lenovo ThinkPad X1 Yoga Hard Drive Replacement, Back Cover: 1 단계, 이미지 2/3 Lenovo ThinkPad X1 Yoga Hard Drive Replacement, Back Cover: 1 단계, 이미지 3/3
    • Be sure to power off and unplug your device before you begin your repair.
    • Flip the computer over so the bottom is facing up.
    • Remove nine 4mm Phillips #1 screws from the bottom of the computer.
    • Use an iFixit opening tool to pry the back cover off of the laptop.
  2. Lenovo ThinkPad X1 Yoga Hard Drive Replacement, Hard Drive: 2 단계, 이미지 1/2 Lenovo ThinkPad X1 Yoga Hard Drive Replacement, Hard Drive: 2 단계, 이미지 2/2
    • Gently peel back the black plastic covering.
    • Remove the single 2mm Phillips #1 screw from the hard drive's silver casing.
  3. Lenovo ThinkPad X1 Yoga Hard Drive Replacement: 3 단계, 이미지 1/1
    • Unplug the hard drive from the computer by pulling away from the computer.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Sam Lanning
회원 가입일: 09/17/19
358 평판
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 27
30일 전: 219
전체 시간: 12,583
