주요 콘텐츠로 건너뛰기
Lenovo ThinkPad X1 Yoga Keyboard Replacement
필요한 것
  1. Lenovo ThinkPad X1 Yoga Keyboard Replacement, Back Cover: 1 단계, 이미지 1/3 Lenovo ThinkPad X1 Yoga Keyboard Replacement, Back Cover: 1 단계, 이미지 2/3 Lenovo ThinkPad X1 Yoga Keyboard Replacement, Back Cover: 1 단계, 이미지 3/3
    • Be sure to power off and unplug your device before you begin your repair.
    • Flip the computer over so the bottom is facing up.
    • Remove nine 4mm Phillips #1 screws from the bottom of the computer.
    • Use an iFixit opening tool to pry the back cover off of the laptop.
  2. Lenovo ThinkPad X1 Yoga Keyboard Replacement, Speakers: 2 단계, 이미지 1/1
    • Remove the five 4.5mm Phillips #1 screws that secure the battery.
  3. Lenovo ThinkPad X1 Yoga Keyboard Replacement: 3 단계, 이미지 1/1
    • Using a pair of tweezers, push the sides of the white speaker wire toward the battery (where it says Lenovo) to unplug it.
  4. Lenovo ThinkPad X1 Yoga Keyboard Replacement: 4 단계, 이미지 1/3 Lenovo ThinkPad X1 Yoga Keyboard Replacement: 4 단계, 이미지 2/3 Lenovo ThinkPad X1 Yoga Keyboard Replacement: 4 단계, 이미지 3/3
    • Remove the speakers from either side of the battery. The connecting wire will unthread from the sides of the battery.
  5. Lenovo ThinkPad X1 Yoga Keyboard Replacement, Battery: 5 단계, 이미지 1/3 Lenovo ThinkPad X1 Yoga Keyboard Replacement, Battery: 5 단계, 이미지 2/3 Lenovo ThinkPad X1 Yoga Keyboard Replacement, Battery: 5 단계, 이미지 3/3
    • Lift the plastic black strip cover that's laying over the battery connector.
    • Use the iFixit opening tool to flip up and disconnect the black battery connector from its motherboard socket.
    • Gently pull the connector away from the battery to pull it out of the slot.
  6. Lenovo ThinkPad X1 Yoga Keyboard Replacement: 6 단계, 이미지 1/1
    • Lift and remove the battery away from the computer.
  7. Lenovo ThinkPad X1 Yoga Keyboard Replacement, Cooling Fan: 7 단계, 이미지 1/1
    • Remove four 4.5mm Phillips #1 screws from the corners of the heat sink.
  8. Lenovo ThinkPad X1 Yoga Keyboard Replacement: 8 단계, 이미지 1/3 Lenovo ThinkPad X1 Yoga Keyboard Replacement: 8 단계, 이미지 2/3 Lenovo ThinkPad X1 Yoga Keyboard Replacement: 8 단계, 이미지 3/3
    • Gently peel back the black plastic covering around the fan.
    • You may hear or feel the adhesive pulling away here.
    • Using an iFixit opening tool, flip up the small black cover of the fan plug.
  9. Lenovo ThinkPad X1 Yoga Keyboard Replacement: 9 단계, 이미지 1/2 Lenovo ThinkPad X1 Yoga Keyboard Replacement: 9 단계, 이미지 2/2
    • Using tweezers, pull the plastic strip out.
  10. Lenovo ThinkPad X1 Yoga Keyboard Replacement: 10 단계, 이미지 1/2 Lenovo ThinkPad X1 Yoga Keyboard Replacement: 10 단계, 이미지 2/2
    • Remove the fan from the computer.
  11. Lenovo ThinkPad X1 Yoga Keyboard Replacement, Wireless chip: 11 단계, 이미지 1/1
    • Gently peel back the black plastic covering.
    • Remove the single Phillips #1 screw securing the wireless chip in place.
  12. Lenovo ThinkPad X1 Yoga Keyboard Replacement: 12 단계, 이미지 1/2 Lenovo ThinkPad X1 Yoga Keyboard Replacement: 12 단계, 이미지 2/2
    • Use an iFixit opening tool to gently pop the gold caps off their connections.
    • Move these wires out of the way.
  13. Lenovo ThinkPad X1 Yoga Keyboard Replacement: 13 단계, 이미지 1/1
    • Slide the chip out.
  14. Lenovo ThinkPad X1 Yoga Keyboard Replacement, Hard Drive: 14 단계, 이미지 1/2 Lenovo ThinkPad X1 Yoga Keyboard Replacement, Hard Drive: 14 단계, 이미지 2/2
    • Remove the single 2mm Phillips #1 screw from the hard drive's silver casing.
  15. Lenovo ThinkPad X1 Yoga Keyboard Replacement: 15 단계, 이미지 1/1
    • Unplug the hard drive from the computer by pulling away from the computer.
  16. Lenovo ThinkPad X1 Yoga Keyboard Replacement, Motherboard: 16 단계, 이미지 1/3 Lenovo ThinkPad X1 Yoga Keyboard Replacement, Motherboard: 16 단계, 이미지 2/3 Lenovo ThinkPad X1 Yoga Keyboard Replacement, Motherboard: 16 단계, 이미지 3/3
    • Using the iFixit opening tool, flip up the eight small covers from the cable connectors.
    • Gently pull the cables out of the slots.
  17. Lenovo ThinkPad X1 Yoga Keyboard Replacement: 17 단계, 이미지 1/2 Lenovo ThinkPad X1 Yoga Keyboard Replacement: 17 단계, 이미지 2/2
    • Using the Phillips #1 screwdriver, remove sixteen 4.5mm screws.
  18. Lenovo ThinkPad X1 Yoga Keyboard Replacement: 18 단계, 이미지 1/1
    • Lift and remove the motherboard away from the computer.
  19. Lenovo ThinkPad X1 Yoga Keyboard Replacement, Keyboard: 19 단계, 이미지 1/2 Lenovo ThinkPad X1 Yoga Keyboard Replacement, Keyboard: 19 단계, 이미지 2/2
    • Using the Phillips #1 screwdriver, remove 23 (twenty three) 4.5mm screws.
  20. Lenovo ThinkPad X1 Yoga Keyboard Replacement: 20 단계, 이미지 1/1
    • Using the iFixit opening tool, lift the metal frame away from the keyboard.
  21. Lenovo ThinkPad X1 Yoga Keyboard Replacement: 21 단계, 이미지 1/1
    • Lift and remove the keyboard away from the computer.
결론
다른 5명이 해당 안내서를 완성하였습니다.
One Comment
Samw steps on gen 4, screws just in different places, thie guide worked great! Thanks :)
Ryan B - 답글
댓글 쓰기
조회 통계:
24 시간 전: 8
7일 전: 84
30일 전: 358
전체 시간: 7,405
