주요 콘텐츠로 건너뛰기
Lenovo ThinkPad X1 Yoga Keyboard Replacement
필요한 것
  1. Lenovo ThinkPad X1 Yoga Keyboard Replacement, Back Cover: 1 단계, 이미지 1/3 Lenovo ThinkPad X1 Yoga Keyboard Replacement, Back Cover: 1 단계, 이미지 2/3 Lenovo ThinkPad X1 Yoga Keyboard Replacement, Back Cover: 1 단계, 이미지 3/3
    • Be sure to power off and unplug your device before you begin your repair.
    • Flip the computer over so the bottom is facing up.
    • Remove nine 4mm Phillips #1 screws from the bottom of the computer.
    • Use an iFixit opening tool to pry the back cover off of the laptop.
  2. Lenovo ThinkPad X1 Yoga Keyboard Replacement, Speakers: 2 단계, 이미지 1/1
    • Remove the five 4.5mm Phillips #1 screws that secure the battery.
  3. Lenovo ThinkPad X1 Yoga Keyboard Replacement: 3 단계, 이미지 1/1
    • Using a pair of tweezers, push the sides of the white speaker wire toward the battery (where it says Lenovo) to unplug it.
  4. Lenovo ThinkPad X1 Yoga Keyboard Replacement: 4 단계, 이미지 1/3 Lenovo ThinkPad X1 Yoga Keyboard Replacement: 4 단계, 이미지 2/3 Lenovo ThinkPad X1 Yoga Keyboard Replacement: 4 단계, 이미지 3/3
    • Remove the speakers from either side of the battery. The connecting wire will unthread from the sides of the battery.
  5. Lenovo ThinkPad X1 Yoga Keyboard Replacement, Battery: 5 단계, 이미지 1/3 Lenovo ThinkPad X1 Yoga Keyboard Replacement, Battery: 5 단계, 이미지 2/3 Lenovo ThinkPad X1 Yoga Keyboard Replacement, Battery: 5 단계, 이미지 3/3
    • Lift the plastic black strip cover that's laying over the battery connector.
    • Use the iFixit opening tool to flip up and disconnect the black battery connector from its motherboard socket.
    • Gently pull the connector away from the battery to pull it out of the slot.
  6. Lenovo ThinkPad X1 Yoga Keyboard Replacement: 6 단계, 이미지 1/1
    • Lift and remove the battery away from the computer.
  7. Lenovo ThinkPad X1 Yoga Keyboard Replacement, Cooling Fan: 7 단계, 이미지 1/1
    • Remove four 4.5mm Phillips #1 screws from the corners of the heat sink.
  8. Lenovo ThinkPad X1 Yoga Keyboard Replacement: 8 단계, 이미지 1/3 Lenovo ThinkPad X1 Yoga Keyboard Replacement: 8 단계, 이미지 2/3 Lenovo ThinkPad X1 Yoga Keyboard Replacement: 8 단계, 이미지 3/3
    • Gently peel back the black plastic covering around the fan.
    • You may hear or feel the adhesive pulling away here.
    • Using an iFixit opening tool, flip up the small black cover of the fan plug.
  9. Lenovo ThinkPad X1 Yoga Keyboard Replacement: 9 단계, 이미지 1/2 Lenovo ThinkPad X1 Yoga Keyboard Replacement: 9 단계, 이미지 2/2
    • Using tweezers, pull the plastic strip out.
  10. Lenovo ThinkPad X1 Yoga Keyboard Replacement: 10 단계, 이미지 1/2 Lenovo ThinkPad X1 Yoga Keyboard Replacement: 10 단계, 이미지 2/2
    • Remove the fan from the computer.
  11. Lenovo ThinkPad X1 Yoga Keyboard Replacement, Wireless chip: 11 단계, 이미지 1/1
    • Gently peel back the black plastic covering.
    • Remove the single Phillips #1 screw securing the wireless chip in place.
  12. Lenovo ThinkPad X1 Yoga Keyboard Replacement: 12 단계, 이미지 1/2 Lenovo ThinkPad X1 Yoga Keyboard Replacement: 12 단계, 이미지 2/2
    • Use an iFixit opening tool to gently pop the gold caps off their connections.
    • Move these wires out of the way.
  13. Lenovo ThinkPad X1 Yoga Keyboard Replacement: 13 단계, 이미지 1/1
    • Slide the chip out.
  14. Lenovo ThinkPad X1 Yoga Keyboard Replacement, Hard Drive: 14 단계, 이미지 1/2 Lenovo ThinkPad X1 Yoga Keyboard Replacement, Hard Drive: 14 단계, 이미지 2/2
    • Remove the single 2mm Phillips #1 screw from the hard drive's silver casing.
  15. Lenovo ThinkPad X1 Yoga Keyboard Replacement: 15 단계, 이미지 1/1
    • Unplug the hard drive from the computer by pulling away from the computer.
  16. Lenovo ThinkPad X1 Yoga Keyboard Replacement, Motherboard: 16 단계, 이미지 1/3 Lenovo ThinkPad X1 Yoga Keyboard Replacement, Motherboard: 16 단계, 이미지 2/3 Lenovo ThinkPad X1 Yoga Keyboard Replacement, Motherboard: 16 단계, 이미지 3/3
    • Using the iFixit opening tool, flip up the eight small covers from the cable connectors.
    • Gently pull the cables out of the slots.
  17. Lenovo ThinkPad X1 Yoga Keyboard Replacement: 17 단계, 이미지 1/2 Lenovo ThinkPad X1 Yoga Keyboard Replacement: 17 단계, 이미지 2/2
    • Using the Phillips #1 screwdriver, remove sixteen 4.5mm screws.
  18. Lenovo ThinkPad X1 Yoga Keyboard Replacement: 18 단계, 이미지 1/1
    • Lift and remove the motherboard away from the computer.
  19. Lenovo ThinkPad X1 Yoga Keyboard Replacement, Keyboard: 19 단계, 이미지 1/2 Lenovo ThinkPad X1 Yoga Keyboard Replacement, Keyboard: 19 단계, 이미지 2/2
    • Using the Phillips #1 screwdriver, remove 23 (twenty three) 4.5mm screws.
  20. Lenovo ThinkPad X1 Yoga Keyboard Replacement: 20 단계, 이미지 1/1
    • Using the iFixit opening tool, lift the metal frame away from the keyboard.
  21. Lenovo ThinkPad X1 Yoga Keyboard Replacement: 21 단계, 이미지 1/1
    • Lift and remove the keyboard away from the computer.
결론
다른 5명이 해당 안내서를 완성하였습니다.
댓글 한 개
Samw steps on gen 4, screws just in different places, thie guide worked great! Thanks :)
Ryan B - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 43
30일 전: 263
전체 시간: 8,081
