주요 콘텐츠로 건너뛰기
Lenovo ThinkPad X100e RAM Replacement
필요한 것
  1. Lenovo ThinkPad X100e RAM Replacement, RAM: 1 단계, 이미지 1/1
    • Power off the device completely.
    • Use the Phillips #0 screwdriver to remove the seven screws that are holding the bottom cover in place.
    • Remove the back cover from the frame.
  2. Lenovo ThinkPad X100e RAM Replacement: 2 단계, 이미지 1/1
    • The RAM will be located at the bottom right corner of the laptop.
  3. Lenovo ThinkPad X100e RAM Replacement: 3 단계, 이미지 1/2 Lenovo ThinkPad X100e RAM Replacement: 3 단계, 이미지 2/2
    • Pull the two mounting clips on either side of the RAM stick away from the RAM stick.
    • The RAM should lift up 30 degrees. Slide it out gently as to not damage the pins.
결론
Replace the RAM by sliding the new stick back into the empty slot until it clicks into place.
Caroline Clark
회원 가입일: 02/08/18
159 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 7
30일 전: 44
전체 시간: 1,116
