주요 콘텐츠로 건너뛰기
Lenovo ThinkPad X140e Battery Replacement
필요한 것
  1. Lenovo ThinkPad X140e Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Turn off your laptop and unplug the charging cable.
    • Failure to remove the charging cable may cause electric shock.
    • Flip the laptop upside down.
    • Rotate the laptop so that the battery is facing away from you.
  2. Lenovo ThinkPad X140e Battery Replacement: 2 단계, 이미지 1/1
    • Push the first switch on the left to the right until you hear a click. This means the battery is unlocked and can be removed.
  3. Lenovo ThinkPad X140e Battery Replacement: 3 단계, 이미지 1/2 Lenovo ThinkPad X140e Battery Replacement: 3 단계, 이미지 2/2
    • Push the second switch on the right to the right, hold it there with your right hand and continue to the next step.
    • While holding the right switch open, take your free hand and pull the battery out.
결론
Dylan Halland
회원 가입일: 10/05/16
318 평판
안내서 2개 작성하였습니다
Cal Poly, Team 20-5, Livingston Fall 2016 Cal Poly, Team 20-5, Livingston Fall 2016 회원
CPSU-LIVINGSTON-F16S20G5
4 회원들
안내서 5개 작성하였습니다
댓글 한 개
I did this, but the computer says that the battery is not genuine, and then refuses to charge the battery. What do I do?
Justine Akehurst - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 11
전체 시간: 990
