소개
Removing the battery is a relatively simple task but is very important to remove power from the laptop in case power shorts any vital components. The x140e battery is a lithium-ion battery, so caution is advised when removing the battery.
필요한 것
Turn off your laptop and unplug the charging cable.
Flip the laptop upside down.
Rotate the laptop so that the battery is facing away from you.
거의 끝나갑니다!
결론
댓글 한 개
I did this, but the computer says that the battery is not genuine, and then refuses to charge the battery. What do I do?
