주요 콘텐츠로 건너뛰기
Lenovo ThinkPad X140e Hard Drive Replacement
필요한 것
  1. Lenovo ThinkPad X140e Hard Drive Replacement, Back Panel: 1 단계, 이미지 1/1
    • Flip the laptop upside down so that the battery is facing away from you.
    • Battery removal is not necessary to complete this guide.
  2. Lenovo ThinkPad X140e Hard Drive Replacement: 2 단계, 이미지 1/2 Lenovo ThinkPad X140e Hard Drive Replacement: 2 단계, 이미지 2/2
    • Locate the three 3 mm Phillips #0 screws on the back panel.
    • Remove each screw using a small Phillips #0 screwdriver.
  3. Lenovo ThinkPad X140e Hard Drive Replacement: 3 단계, 이미지 1/1
    • Using a small plastic opening tool, pry off the back casing starting at a point closest to you and working around the perimeter of the case.
  4. Lenovo ThinkPad X140e Hard Drive Replacement, Hard Drive: 4 단계, 이미지 1/1
    • After removing the back panel, locate the hard drive located to the far left. It is distinguishable from other parts based on it's rectangular shape.
  5. Lenovo ThinkPad X140e Hard Drive Replacement: 5 단계, 이미지 1/2 Lenovo ThinkPad X140e Hard Drive Replacement: 5 단계, 이미지 2/2
    • Remove the four 3.5 mm Phillips #0 screws attached on the four corners of the hard drive.
  6. Lenovo ThinkPad X140e Hard Drive Replacement: 6 단계, 이미지 1/2 Lenovo ThinkPad X140e Hard Drive Replacement: 6 단계, 이미지 2/2
    • Slide the hard drive to the left.
    • Grip the hard drive on both sides and proceed to lift up to remove the hard drive.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
kevin hull
회원 가입일: 10/05/16
213 평판
안내서 2개 작성하였습니다
Cal Poly, Team 20-5, Livingston Fall 2016 Cal Poly, Team 20-5, Livingston Fall 2016 회원
CPSU-LIVINGSTON-F16S20G5
4 회원들
안내서 5개 작성하였습니다
댓글 한 개
How do you reformat the hard-drive? I understand physically replacing the equipment, but how do I reformat it with a windows operating system? My email is amwindham@aol.com.
amwindham - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 9
30일 전: 17
전체 시간: 1,654
