주요 콘텐츠로 건너뛰기
Lenovo ThinkPad X140e Keyboard Replacement
필요한 것
  1. Lenovo ThinkPad X140e Keyboard Replacement, Keyboard: 1 단계, 이미지 1/1
    • Set the laptop facing you with the screen open.
  2. Lenovo ThinkPad X140e Keyboard Replacement: 2 단계, 이미지 1/2 Lenovo ThinkPad X140e Keyboard Replacement: 2 단계, 이미지 2/2
    • Using a small plastic opening tool, pry off the keyboard starting at a point closest to you and working around the perimeter.
  3. Lenovo ThinkPad X140e Keyboard Replacement: 3 단계, 이미지 1/3 Lenovo ThinkPad X140e Keyboard Replacement: 3 단계, 이미지 2/3 Lenovo ThinkPad X140e Keyboard Replacement: 3 단계, 이미지 3/3
    • Flip up the ZIF connector that is holding the small ribbon cable in place.
    • Proceed to pull out the small ribbon cable
  4. Lenovo ThinkPad X140e Keyboard Replacement: 4 단계, 이미지 1/3 Lenovo ThinkPad X140e Keyboard Replacement: 4 단계, 이미지 2/3 Lenovo ThinkPad X140e Keyboard Replacement: 4 단계, 이미지 3/3
    • Flip up the ZIF connector that is holding the larger ribbon cable in place.
    • Proceed to pull out the large ribbon cable.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
kevin hull
회원 가입일: 10/05/16
213 평판
안내서 2개 작성하였습니다
Cal Poly, Team 20-5, Livingston Fall 2016 Cal Poly, Team 20-5, Livingston Fall 2016 회원
CPSU-LIVINGSTON-F16S20G5
4 회원들
안내서 5개 작성하였습니다
댓글 4개
how can I buy a keyboard for my lenovo thinkpad x140e laptop?
Bryan - 답글
The keyboard for the X140e is the same as the one for the X130e and the X131e and the X121e.
It is FRU 04y0379
Buy the keyboard on eBay.
atexit8 -
Just as a note, there are two screws that keep that keyboard held in place. You need to remove the back panel and take out those two screws, otherwise you’re going to have a tough time. Also, you really don’t need the pry tool, once those screws are out, the keyboard slides off. The rest of the process is spot on.
Jeffrey Chocklette - 답글
Don’t forget the screws, otherwise you will never get the keyboard off or worse damage it during removal
celticxxtwin - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 6
30일 전: 18
전체 시간: 1,726
