주요 콘텐츠로 건너뛰기
Lenovo ThinkPad X140e Speakers Replacement
필요한 것
  1. Lenovo ThinkPad X140e Speakers Replacement, Keyboard: 1 단계, 이미지 1/1
    • Set the laptop facing you with the screen open.
  2. Lenovo ThinkPad X140e Speakers Replacement: 2 단계, 이미지 1/2 Lenovo ThinkPad X140e Speakers Replacement: 2 단계, 이미지 2/2
    • Using a small plastic opening tool, pry off the keyboard starting at a point closest to you and working around the perimeter.
  3. Lenovo ThinkPad X140e Speakers Replacement: 3 단계, 이미지 1/3 Lenovo ThinkPad X140e Speakers Replacement: 3 단계, 이미지 2/3 Lenovo ThinkPad X140e Speakers Replacement: 3 단계, 이미지 3/3
    • Flip up the ZIF connector that is holding the small ribbon cable in place.
    • Proceed to pull out the small ribbon cable
  4. Lenovo ThinkPad X140e Speakers Replacement: 4 단계, 이미지 1/3 Lenovo ThinkPad X140e Speakers Replacement: 4 단계, 이미지 2/3 Lenovo ThinkPad X140e Speakers Replacement: 4 단계, 이미지 3/3
    • Flip up the ZIF connector that is holding the larger ribbon cable in place.
    • Proceed to pull out the large ribbon cable.
  5. Lenovo ThinkPad X140e Speakers Replacement, Speakers: 5 단계, 이미지 1/1
    • Flip the laptop upside down such that the battery would be facing away from you.
    • Remove the two 3mm Phillips #0 screws in the back located on either side of the battery.
    • Back panel and battery removal are not necessary for completion of this guide.
  6. Lenovo ThinkPad X140e Speakers Replacement: 6 단계, 이미지 1/2 Lenovo ThinkPad X140e Speakers Replacement: 6 단계, 이미지 2/2
    • Flip the laptop right-side up and open it so that the screen is facing you.
    • Pry off the front panel using a small plastic opening tool starting at a corner and working around the perimeter
  7. Lenovo ThinkPad X140e Speakers Replacement: 7 단계, 이미지 1/2 Lenovo ThinkPad X140e Speakers Replacement: 7 단계, 이미지 2/2
    • The speakers are located on the bottom of the laptop, where the mouse pad is located.
    • Remove the four 4.5 mm Phillips #0 screws on either side of both speakers.
  8. Lenovo ThinkPad X140e Speakers Replacement: 8 단계, 이미지 1/3 Lenovo ThinkPad X140e Speakers Replacement: 8 단계, 이미지 2/3 Lenovo ThinkPad X140e Speakers Replacement: 8 단계, 이미지 3/3
    • Remove the cable that is attached from the speakers to the board.
    • Unhook the black wire that connects the speaker on the left to the speaker on the right.
    • After unhooking the wire, simply pull the speakers out of the laptop.
결론
Dylan Halland
회원 가입일: 10/05/16
318 평판
안내서 2개 작성하였습니다
Cal Poly, Team 20-5, Livingston Fall 2016 Cal Poly, Team 20-5, Livingston Fall 2016 회원
CPSU-LIVINGSTON-F16S20G5
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 5
30일 전: 30
전체 시간: 2,876
