주요 콘텐츠로 건너뛰기
Lenovo ThinkPad X240 - Hard Disk Drive Replacement
필요한 것
  1. Lenovo ThinkPad X240 -  Hard Disk Drive  Replacement, Hard Disk Drive and Solid State Drive: 1 단계, 이미지 1/1
    • Flip the laptop upside down as shown in the photo.
  2. Lenovo ThinkPad X240 -  Hard Disk Drive  Replacement: 2 단계, 이미지 1/2 Lenovo ThinkPad X240 -  Hard Disk Drive  Replacement: 2 단계, 이미지 2/2
    • Remove the 8 0.2mm Phillips screws connecting the back cover to the laptop.
  3. Lenovo ThinkPad X240 -  Hard Disk Drive  Replacement: 3 단계, 이미지 1/1
    • Remove the back cover using the opening tools.
    • Gently use the plastic opening tools to prevent scratching your device.
  4. Lenovo ThinkPad X240 -  Hard Disk Drive  Replacement: 4 단계, 이미지 1/1
    • Remove the Hard Disk Drive card by screwing the 2 0.2mm Phillips screw
  5. Lenovo ThinkPad X240 -  Hard Disk Drive  Replacement: 5 단계, 이미지 1/1
    • Disconnect the SATA cable from the hard drive.
  6. Lenovo ThinkPad X240 -  Hard Disk Drive  Replacement: 6 단계, 이미지 1/1
    • Take off the connector by carefully popping its holders out of place
  7. Lenovo ThinkPad X240 -  Hard Disk Drive  Replacement: 7 단계, 이미지 1/1
    • Reconnect the cable to the new Hard Disk Drive
  8. Lenovo ThinkPad X240 -  Hard Disk Drive  Replacement: 8 단계, 이미지 1/1
    • place the connector in order to hold the cable
  9. Lenovo ThinkPad X240 -  Hard Disk Drive  Replacement: 9 단계, 이미지 1/1
    • Place the new Hard Drive Disk
결론
다른 9명이 해당 안내서를 완성하였습니다.
Mohammed Alsaadi
회원 가입일: 09/20/17
567 평판
안내서 2개 작성하였습니다
댓글 6개
Hello, i think you forgot to disconnect internal battery first before you replace something
shofaribagus - 답글
That is true, that'd been a much safer way to do it.
Mahir Max -
Tip for the case screws, they are captive don’t worry about them
Baddo-M _ - 답글
Yes, good point - case screws are captive and easy to keep in place when lifting the cover. But overall this is a well written guide, so thanks for this.
Ricky Las Vegas - 답글
If you have an SD card in the SD card reader make sure to remove it before trying to remove the case cover, otherwise it will not come off, and you risk damaging your motherboard if you force it.
David Huggins-Daines - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 21
30일 전: 75
전체 시간: 15,243
