주요 콘텐츠로 건너뛰기
Lenovo ThinkPad X260 Internal Battery Replacement
필요한 것
  1. Lenovo ThinkPad X260 Internal Battery Replacement, External Battery: 1 단계, 이미지 1/2 Lenovo ThinkPad X260 Internal Battery Replacement, External Battery: 1 단계, 이미지 2/2
    • Make sure that the device is unplugged and turned off.
    • Flip the laptop from the front to the back.
  2. Lenovo ThinkPad X260 Internal Battery Replacement: 2 단계, 이미지 1/3 Lenovo ThinkPad X260 Internal Battery Replacement: 2 단계, 이미지 2/3 Lenovo ThinkPad X260 Internal Battery Replacement: 2 단계, 이미지 3/3
    • Start by pinching the switches on either side of the battery outwards.
    • At the same time push the external battery, located in the back, upwards.
    • Remove the external battery from the laptop.
  3. Lenovo ThinkPad X260 Internal Battery Replacement, Back Cover: 3 단계, 이미지 1/3 Lenovo ThinkPad X260 Internal Battery Replacement, Back Cover: 3 단계, 이미지 2/3 Lenovo ThinkPad X260 Internal Battery Replacement, Back Cover: 3 단계, 이미지 3/3
    • Loosen the eight 4.2 mm screws holding the back cover on using a Phillips #1 screwdriver.
    • These screws should be held in place by a small plastic washer which secures them to the cover and should not be loosened. This is illustrated in the third image.
  4. Lenovo ThinkPad X260 Internal Battery Replacement: 4 단계, 이미지 1/3 Lenovo ThinkPad X260 Internal Battery Replacement: 4 단계, 이미지 2/3 Lenovo ThinkPad X260 Internal Battery Replacement: 4 단계, 이미지 3/3
    • Gently pull the cover off and set aside.
    • An iFixit opening tool may make it easier to gently remove the cover.
  5. Lenovo ThinkPad X260 Internal Battery Replacement, Internal Battery: 5 단계, 이미지 1/2 Lenovo ThinkPad X260 Internal Battery Replacement, Internal Battery: 5 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Detach the black battery connector using a pair of tweezers.
  6. Lenovo ThinkPad X260 Internal Battery Replacement: 6 단계, 이미지 1/1
    • Remove the four 3.3 mm screws locking down the battery using a Phillips #1 screwdriver.
  7. Lenovo ThinkPad X260 Internal Battery Replacement: 7 단계, 이미지 1/3 Lenovo ThinkPad X260 Internal Battery Replacement: 7 단계, 이미지 2/3 Lenovo ThinkPad X260 Internal Battery Replacement: 7 단계, 이미지 3/3
    • Carefully remove the internal battery unit from the laptop using an iFixit opening tool.
    • Pick up the battery and take it off the laptop frame.
결론
Ammarin Sinthana
회원 가입일: 07/13/23
97 평판
안내서 1개 작성함
IUPUI, Team 1-3, Harley Summer 2023 IUPUI, Team 1-3, Harley Summer 2023 회원
IUPUI-HARLEY-SU23S1G3
3 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 7
7일 전: 36
30일 전: 138
전체 시간: 1,439
