주요 콘텐츠로 건너뛰기
Lenovo ThinkPad X270 RAM Replacement
필요한 것
  1. Lenovo ThinkPad X270 RAM Replacement, Prepare your laptop for disassembly: 1 단계, 이미지 1/2 Lenovo ThinkPad X270 RAM Replacement, Prepare your laptop for disassembly: 1 단계, 이미지 2/2
    • Allow your laptop's battery to drain below 25% before starting this repair—a charged battery may catch fire if damaged.
    • Unplug all cables and fully shut down your laptop.
  2. Lenovo ThinkPad X270 RAM Replacement, Remove the micro SIM card tray: 2 단계, 이미지 1/3 Lenovo ThinkPad X270 RAM Replacement, Remove the micro SIM card tray: 2 단계, 이미지 2/3 Lenovo ThinkPad X270 RAM Replacement, Remove the micro SIM card tray: 2 단계, 이미지 3/3
    • A SIM eject tool or bit isn't long enough to eject the tray.
    • Insert a straightened paper clip into the micro SIM card tray hole on the right edge of the laptop.
    • Press the paper clip firmly into the hole to eject the tray.
    • Remove the tray.
    • When reinserting the tray, slide the arms of the tray into the rectangular metal slot.
  3. Lenovo ThinkPad X270 RAM Replacement, Battery information: 3 단계, 이미지 1/2 Lenovo ThinkPad X270 RAM Replacement, Battery information: 3 단계, 이미지 2/2
    • Lay your laptop upside down to access the external battery.
    • Two sliding tabs secure the battery.
  4. Lenovo ThinkPad X270 RAM Replacement, Release the left tab: 4 단계, 이미지 1/2 Lenovo ThinkPad X270 RAM Replacement, Release the left tab: 4 단계, 이미지 2/2
    • Slide the left tab, labeled 1, to the unlocked position—it'll click into place and release the left side of the battery.
  5. Lenovo ThinkPad X270 RAM Replacement, Remove the battery: 5 단계, 이미지 1/3 Lenovo ThinkPad X270 RAM Replacement, Remove the battery: 5 단계, 이미지 2/3 Lenovo ThinkPad X270 RAM Replacement, Remove the battery: 5 단계, 이미지 3/3
    • Hold the right tab, labeled 2, in the unlocked position and slide the battery out of its recess.
    • During reassembly, slide the battery into its recess until both tabs engage.
    • Never reuse a deformed or damaged battery—it's a fire hazard. Replace it with a new battery.
  6. Lenovo ThinkPad X270 RAM Replacement, Unfasten the back cover: 6 단계, 이미지 1/2 Lenovo ThinkPad X270 RAM Replacement, Unfasten the back cover: 6 단계, 이미지 2/2
    • Use a Phillips screwdriver to loosen the eight captive screws securing the back cover.
    • Don't try to completely remove the screws—they're secured to the back cover with delicate, plastic clips.
  7. Lenovo ThinkPad X270 RAM Replacement, Insert an opening pick: 7 단계, 이미지 1/3 Lenovo ThinkPad X270 RAM Replacement, Insert an opening pick: 7 단계, 이미지 2/3 Lenovo ThinkPad X270 RAM Replacement, Insert an opening pick: 7 단계, 이미지 3/3
    • Plastic clips secure the back cover to the frame. You'll hear and feel the clips release.
    • Insert the flat side of an opening pick between the bottom right edge of the back cover and frame.
    • Pry up the back cover to release the bottom right clips.
    • Leave the pick inserted in the bottom right corner.
  8. Lenovo ThinkPad X270 RAM Replacement, Release the bottom edge clips: 8 단계, 이미지 1/3 Lenovo ThinkPad X270 RAM Replacement, Release the bottom edge clips: 8 단계, 이미지 2/3 Lenovo ThinkPad X270 RAM Replacement, Release the bottom edge clips: 8 단계, 이미지 3/3
    • During the next two steps, position your pick downward at a 45-degree angle to help release the clips.
    • Slide the pick to the bottom left corner to release the bottom clips.
  9. Lenovo ThinkPad X270 RAM Replacement, Release the left edge clips: 9 단계, 이미지 1/2 Lenovo ThinkPad X270 RAM Replacement, Release the left edge clips: 9 단계, 이미지 2/2
    • Insert your pick in the bottom left corner and slide the pick to the first USB port to release the left clips.
  10. Lenovo ThinkPad X270 RAM Replacement, Release the top corner clips: 10 단계, 이미지 1/3 Lenovo ThinkPad X270 RAM Replacement, Release the top corner clips: 10 단계, 이미지 2/3 Lenovo ThinkPad X270 RAM Replacement, Release the top corner clips: 10 단계, 이미지 3/3
    • Insert an opening tool between the top left corner of the back cover and frame.
    • Pry the back cover up to release the clips securing its top left corner.
    • Repeat the process on the top right corner.
  11. Lenovo ThinkPad X270 RAM Replacement, Release the top edge clips: 11 단계, 이미지 1/3 Lenovo ThinkPad X270 RAM Replacement, Release the top edge clips: 11 단계, 이미지 2/3 Lenovo ThinkPad X270 RAM Replacement, Release the top edge clips: 11 단계, 이미지 3/3
    • Five clips secure the top edge of the back cover.
    • Insert an opening tool in the gap between the back cover and frame, next to one of the clips.
    • Push the opening tool into the gap until the clip releases.
  12. Lenovo ThinkPad X270 RAM Replacement: 12 단계, 이미지 1/3 Lenovo ThinkPad X270 RAM Replacement: 12 단계, 이미지 2/3 Lenovo ThinkPad X270 RAM Replacement: 12 단계, 이미지 3/3
    • Push the opening tool between the back cover and frame at different points along the top edge to release the remaining clips.
  13. Lenovo ThinkPad X270 RAM Replacement, Remove the back cover: 13 단계, 이미지 1/3 Lenovo ThinkPad X270 RAM Replacement, Remove the back cover: 13 단계, 이미지 2/3 Lenovo ThinkPad X270 RAM Replacement, Remove the back cover: 13 단계, 이미지 3/3
    • Remove the back cover.
    • During reassembly, lay the back cover on the frame and press firmly around the perimeter to engage all the clips.
  14. Lenovo ThinkPad X270 RAM Replacement, Disconnect the internal battery: 14 단계, 이미지 1/3 Lenovo ThinkPad X270 RAM Replacement, Disconnect the internal battery: 14 단계, 이미지 2/3 Lenovo ThinkPad X270 RAM Replacement, Disconnect the internal battery: 14 단계, 이미지 3/3
  15. Lenovo ThinkPad X270 RAM Replacement, Remove the RAM: 15 단계, 이미지 1/3 Lenovo ThinkPad X270 RAM Replacement, Remove the RAM: 15 단계, 이미지 2/3 Lenovo ThinkPad X270 RAM Replacement, Remove the RAM: 15 단계, 이미지 3/3
    • Two metal arms secure the stick of RAM.
    • Simultaneously push out the arms until they disengage and the stick pops up at a slight angle.
    • Remove the stick of RAM.
    • To install a stick of RAM, insert it into its socket at a slight downward angle and push down firmly until both metal arms lock the stick in place.
결론
Check your repair by running hardware tests with Lenovo Diagnostics.
Spencer Day
회원 가입일: 09/14/22
54,795 평판
안내서 407개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 17,277개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 49
30일 전: 190
전체 시간: 1,385
