주요 콘텐츠로 건너뛰기
Lenovo ThinkPad X280 CMOS Battery Replacement
필요한 것
  1. Lenovo ThinkPad X280 CMOS Battery Replacement, Back Panel: 1 단계, 이미지 1/1
    • To begin, ensure that the device is completely powered off and not connected to an energy supply.
    • Close the device and flip it over to expose the back panel.
  2. Lenovo ThinkPad X280 CMOS Battery Replacement: 2 단계, 이미지 1/2 Lenovo ThinkPad X280 CMOS Battery Replacement: 2 단계, 이미지 2/2
    • Use a Phillips #1 screwdriver to unscrew the five captive screws on the back panel until a small pop is heard.
    • These are captive screws and do not come out completely.
  3. Lenovo ThinkPad X280 CMOS Battery Replacement: 3 단계, 이미지 1/2 Lenovo ThinkPad X280 CMOS Battery Replacement: 3 단계, 이미지 2/2
    • Gently wedge an opening tool or spudger under the back panel, and loosen the clips around the perimeter until the back panel comes off.
    • Remove the back cover.
  4. Lenovo ThinkPad X280 CMOS Battery Replacement, Battery: 4 단계, 이미지 1/3 Lenovo ThinkPad X280 CMOS Battery Replacement, Battery: 4 단계, 이미지 2/3 Lenovo ThinkPad X280 CMOS Battery Replacement, Battery: 4 단계, 이미지 3/3
    • Using the Phillips #1 screwdriver, remove the four 5 mm screws that are holding the battery down.
    • Remove the battery.
  5. Lenovo ThinkPad X280 CMOS Battery Replacement, CMOS Battery: 5 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Use tweezers to gently unplug the CMOS Battery from the port on the right side.
  6. Lenovo ThinkPad X280 CMOS Battery Replacement: 6 단계, 이미지 1/1
    • Work the wire out from its holding brackets and is now free to be removed.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Hannah Bryn Cullen
회원 가입일: 10/03/22
415 평판
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 7
7일 전: 34
30일 전: 162
전체 시간: 2,350
