주요 콘텐츠로 건너뛰기
Lenovo ThinkPad X280 Keyboard Replacement
필요한 것
  1. Lenovo ThinkPad X280 Keyboard Replacement, Keyboard: 1 단계, 이미지 1/1
    • To begin, ensure that the device is powered off and not plugged into a energy supply.
    • Open the device to where you are directly viewing the screen with the keyboard laying flat.
  2. Lenovo ThinkPad X280 Keyboard Replacement: 2 단계, 이미지 1/1
    • Using the flat end of the spudger, insert it at the top of the right click button.
    • Pry it up to remove the button.
    • Repeat for the left click button.
  3. Lenovo ThinkPad X280 Keyboard Replacement: 3 단계, 이미지 1/1
    • Use the Phillips #0 screwdriver to remove the two 5 mm screws.
  4. Lenovo ThinkPad X280 Keyboard Replacement: 4 단계, 이미지 1/1
    • Using the black spudger tool, gently lift under the plastic where the screws were located.
    • Slide the keyboard towards the screen of the LenovoThinkPad X280 and lift the front edge by hand.
  5. Lenovo ThinkPad X280 Keyboard Replacement: 5 단계, 이미지 1/1
    • Gently remove the keyboard from the device and flip it over.
    • It should still be attached with connectors on the far left corner at the top so be careful not to rip or pull the keyboard out.
  6. Lenovo ThinkPad X280 Keyboard Replacement: 6 단계, 이미지 1/1
    • Disconnect the keyboard and trackpad cables locks with the pointed end of the black spudger.
  7. Lenovo ThinkPad X280 Keyboard Replacement: 7 단계, 이미지 1/2 Lenovo ThinkPad X280 Keyboard Replacement: 7 단계, 이미지 2/2
    • Gently pull the cables from the rectangular connection site to detach the keyboard.
    • Remove the keyboard.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Jordan Wooten
회원 가입일: 09/05/21
609 평판
안내서 4개 작성하였습니다
University of Alabama, Team 1-3, Bedsole Fall 2021 University of Alabama, Team 1-3, Bedsole Fall 2021 회원
UA-BEDSOLE-F21S1G3
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 25
30일 전: 150
전체 시간: 3,611
