주요 콘텐츠로 건너뛰기
Lenovo ThinkPad X280 Wi-Fi Card Replacement
필요한 것
  1. Lenovo ThinkPad X280 Wi-Fi Card Replacement, Back Panel: 1 단계, 이미지 1/1
    • To begin, ensure that the device is completely powered off and not connected to an energy supply.
    • Close the device and flip it over to expose the back panel.
  2. Lenovo ThinkPad X280 Wi-Fi Card Replacement: 2 단계, 이미지 1/2 Lenovo ThinkPad X280 Wi-Fi Card Replacement: 2 단계, 이미지 2/2
    • Use a Phillips #1 screwdriver to unscrew the five captive screws on the back panel until a small pop is heard.
    • These are captive screws and do not come out completely.
  3. Lenovo ThinkPad X280 Wi-Fi Card Replacement: 3 단계, 이미지 1/2 Lenovo ThinkPad X280 Wi-Fi Card Replacement: 3 단계, 이미지 2/2
    • Gently wedge an opening tool or spudger under the back panel, and loosen the clips around the perimeter until the back panel comes off.
    • Remove the back cover.
  4. Lenovo ThinkPad X280 Wi-Fi Card Replacement, Wi-Fi Card: 4 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Use tweezers to gently disconnect the two wires that are connected to the Wi-Fi card.
    • They should pop off with minimal force.
  5. Lenovo ThinkPad X280 Wi-Fi Card Replacement: 5 단계, 이미지 1/1
    • Use a Phillips #1 screwdriver to remove the single screw that secures the Wi-Fi card.
    • Be careful not to over-tighten the screw when reassembling, should be thumb tight
  6. Lenovo ThinkPad X280 Wi-Fi Card Replacement: 6 단계, 이미지 1/1
    • Use tweezers or your fingers to gently pull the Wi-Fi card from its port.
    • Pull directly away from the port, parallel with the card. Do not pull up towards yourself.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Hannah Bryn Cullen
회원 가입일: 10/03/22
415 평판
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 8
30일 전: 62
전체 시간: 978
