소개
If you need to replace your laptop’s fan please refer to this guide. Exercise caution before beginning this guide by ensuring that the laptop is unplugged and turned off. To complete the replacement of your fan, you will need a plastic opening tool, a #0 Philips head screw driver, and a pair of tweezers.
필요한 것
Flip your laptop over and place on a flat surface so you can access the screws on the base cover.
Using a Phillips #0 screwdriver, unscrew the five screws on the base cover.
다른 한 분이 해당 안내서를 완성하였습니다.
