주요 콘텐츠로 건너뛰기
Lenovo ThinkPad X390 Motherboard Replacement
필요한 것
  1. Lenovo ThinkPad X390 Motherboard Replacement, Motherboard: 1 단계, 이미지 1/1
    • Power down and unplug the laptop before proceeding.
    • Use a Phillips #0 screwdriver to remove the five screws on the base cover.
  2. Lenovo ThinkPad X390 Motherboard Replacement: 2 단계, 이미지 1/1
    • Insert a plastic opening tool between the base cover and the chassis.
    • Slide the tool along the perimeter of the case and push down as you go to release the base cover.
    • Lift the base cover up and off.
  3. Lenovo ThinkPad X390 Motherboard Replacement: 3 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Use tweezers to grip the battery's motherboard plug, and pull the plug directly out of its port.
  4. Lenovo ThinkPad X390 Motherboard Replacement: 4 단계, 이미지 1/1
    • Use a Phillips #0 screwdriver to remove the four 5.2 mm screws securing the battery.
  5. Lenovo ThinkPad X390 Motherboard Replacement: 5 단계, 이미지 1/1
    • Lift the battery up and out of its housing.
  6. Lenovo ThinkPad X390 Motherboard Replacement: 6 단계, 이미지 1/2 Lenovo ThinkPad X390 Motherboard Replacement: 6 단계, 이미지 2/2
    • Remove the four 5.2 mm screws from the fan using the Phillips #0 screwdriver.
    • Use tweezers to carefully unplug the fan ribbon cable.
  7. Lenovo ThinkPad X390 Motherboard Replacement: 7 단계, 이미지 1/1
    • Remove the eleven 5.2 mm screws from the motherboard using a Phillips #0 screwdriver.
  8. Lenovo ThinkPad X390 Motherboard Replacement: 8 단계, 이미지 1/1
    • Use tweezers to carefully unplug the four motherboard ribbon cables.
  9. Lenovo ThinkPad X390 Motherboard Replacement: 9 단계, 이미지 1/1
    • Use tweezers to carefully unplug the black and red harness cables.
  10. Lenovo ThinkPad X390 Motherboard Replacement: 10 단계, 이미지 1/1
    • Carefully lift the motherboard up and out.
결론
Colton Horvath
회원 가입일: 02/10/22
442 평판
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 11
30일 전: 89
전체 시간: 1,678
