주요 콘텐츠로 건너뛰기
Lenovo ThinkPad X390 SSD Replacement
필요한 것
  1. Lenovo ThinkPad X390 SSD Replacement, SSD: 1 단계, 이미지 1/1
    • Shut down and unplug the laptop before proceeding.
    • Use a Phillips #0 screwdriver to remove the five 2.7 mm screws on the base cover.
  2. Lenovo ThinkPad X390 SSD Replacement: 2 단계, 이미지 1/1
    • Insert a plastic opening tool between the base cover and the chassis.
    • Slide the tool along the perimeter of the case and push down as you go to release the base cover.
    • Lift the base cover up and off.
  3. Lenovo ThinkPad X390 SSD Replacement: 3 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Use tweezers to grip the battery's motherboard plug, and pull the plug directly out of its port.
  4. Lenovo ThinkPad X390 SSD Replacement: 4 단계, 이미지 1/1
    • Use a Phillips #0 screwdriver to remove the four 5.2 mm screws securing the battery.
  5. Lenovo ThinkPad X390 SSD Replacement: 5 단계, 이미지 1/1
    • Using your hands, remove the battery from the laptop.
    • Lift the battery up and out of its housing.
  6. Lenovo ThinkPad X390 SSD Replacement: 6 단계, 이미지 1/1
    • Use a Phillips #0 screwdriver to remove the single 2.9 mm screw securing the SSD to the motherboard.
  7. Lenovo ThinkPad X390 SSD Replacement: 7 단계, 이미지 1/1
    • Grip the SSD, and gently pull it directly out of its port.
결론
Colton Horvath
회원 가입일: 02/10/22
442 평판
안내서 3개 작성하였습니다
댓글 한 개
I have been building computers for 15+ years, i didn't go to a fancy college but even I know this tutorial is for replacing the SSD or M.2 to be specific for a X390 laptop. this is not the ram module
Patrick Timmel - 답글
댓글 쓰기
조회 통계:
24 시간 전: 7
7일 전: 31
30일 전: 146
전체 시간: 3,279
