주요 콘텐츠로 건너뛰기
Lenovo ThinkPad X390 Yoga Display Replacement
필요한 것
  1. Lenovo ThinkPad X390 Yoga Display Replacement, Back Case: 1 단계, 이미지 1/1
    • Use a Phillips #1 screwdriver to unscrew the eight captive screws from the back of the device.
    • The screws should not be removed from the back panel, so don't try to force them out.
  2. Lenovo ThinkPad X390 Yoga Display Replacement: 2 단계, 이미지 1/1
    • Use the iFixit opening tool to remove the back case by entering the tip of the tool into the seam and prying up.
    • This can be tough so take your time to undo the clips around the perimeter before removing the back cover.
  3. Lenovo ThinkPad X390 Yoga Display Replacement: 3 단계, 이미지 1/1
    • Once the back cover is no longer attached carefully remove it by lifting straight up.
  4. Lenovo ThinkPad X390 Yoga Display Replacement, Display: 4 단계, 이미지 1/2 Lenovo ThinkPad X390 Yoga Display Replacement, Display: 4 단계, 이미지 2/2
    • Disconnect the display connectors with a spudger or opening tool.
  5. Lenovo ThinkPad X390 Yoga Display Replacement: 5 단계, 이미지 1/1
    • Loosen the two 5.5mm screws using the Phillips #1 screwdriver.
결론
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 5
30일 전: 51
전체 시간: 890
