주요 콘텐츠로 건너뛰기
Lenovo ThinkPad X390 Yoga Keyboard Replacement
필요한 것
  1. Lenovo ThinkPad X390 Yoga Keyboard Replacement, Back Case: 1 단계, 이미지 1/1
    • Use a Phillips #1 screwdriver to unscrew the eight captive screws from the back of the device.
    • The screws should not be removed from the back panel, so don't try to force them out.
  2. Lenovo ThinkPad X390 Yoga Keyboard Replacement: 2 단계, 이미지 1/1
    • Use the iFixit opening tool to remove the back case by entering the tip of the tool into the seam and prying up.
    • This can be tough so take your time to undo the clips around the perimeter before removing the back cover.
  3. Lenovo ThinkPad X390 Yoga Keyboard Replacement: 3 단계, 이미지 1/1
    • Once the back cover is no longer attached carefully remove it by lifting straight up.
  4. Lenovo ThinkPad X390 Yoga Keyboard Replacement, Battery: 4 단계, 이미지 1/1
    • Use the spudger to disconnect the battery from the motherboard at the connector socket.
  5. Lenovo ThinkPad X390 Yoga Keyboard Replacement: 5 단계, 이미지 1/1
    • Use the Phillips #1 screwdriver to remove five 4 mm screws around the battery.
  6. Lenovo ThinkPad X390 Yoga Keyboard Replacement: 6 단계, 이미지 1/1
    • Lift the battery out of the laptop by lifting up.
  7. Lenovo ThinkPad X390 Yoga Keyboard Replacement, Fan: 7 단계, 이미지 1/1
    • Disconnect the fan connector from the moetherboard with a spudger or opening tool.
  8. Lenovo ThinkPad X390 Yoga Keyboard Replacement: 8 단계, 이미지 1/1
    • Loosen the seven screws surrounding the fan and heatsink using the Phillips #1 screwdriver.
  9. Lenovo ThinkPad X390 Yoga Keyboard Replacement: 9 단계, 이미지 1/1
    • Carefully remove the fan from the laptop by lifting it up and off the frame.
  10. Lenovo ThinkPad X390 Yoga Keyboard Replacement, Motherboard: 10 단계, 이미지 1/1
    • Disconnect the motherboard connectors with a spudger or opening tool.
  11. Lenovo ThinkPad X390 Yoga Keyboard Replacement: 11 단계, 이미지 1/1
    • Use the Phillips #1 screwdriver to remove nine 5 mm screws around the motherboard.
  12. Lenovo ThinkPad X390 Yoga Keyboard Replacement: 12 단계, 이미지 1/1
    • Loosen the sixty-eight 2 mm screws using the Phillips #1 screwdriver.
  13. Lenovo ThinkPad X390 Yoga Keyboard Replacement: 13 단계, 이미지 1/1
    • Carefully remove the motherboard from the laptop by lifting it up and off the frame.
  14. Lenovo ThinkPad X390 Yoga Keyboard Replacement, Keyboard: 14 단계, 이미지 1/1
    • Gently remove keyboard
결론
Louise Bonnimond
회원 가입일: 10/03/22
181 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 10
7일 전: 18
30일 전: 104
전체 시간: 2,092
