주요 콘텐츠로 건너뛰기
Lenovo ThinkPad X390 Yoga SSD Replacement
필요한 것
  1. Lenovo ThinkPad X390 Yoga SSD Replacement, Back Case: 1 단계, 이미지 1/1
    • Use a Phillips #1 screwdriver to unscrew the eight captive screws from the back of the device.
    • The screws should not be removed from the back panel, so don't try to force them out.
  2. Lenovo ThinkPad X390 Yoga SSD Replacement: 2 단계, 이미지 1/1
    • Use the iFixit opening tool to remove the back case by entering the tip of the tool into the seam and prying up.
    • This can be tough so take your time to undo the clips around the perimeter before removing the back cover.
  3. Lenovo ThinkPad X390 Yoga SSD Replacement: 3 단계, 이미지 1/1
    • Once the back cover is no longer attached carefully remove it by lifting straight up.
  4. Lenovo ThinkPad X390 Yoga SSD Replacement, SSD: 4 단계, 이미지 1/1
    • Use the Phillips #1 screwdriver to remove the 4 mm screw holding the SSD in place .
  5. Lenovo ThinkPad X390 Yoga SSD Replacement: 5 단계, 이미지 1/1
    • Pull the SSD out from the connection to remove it.
결론
Scott Merchant
회원 가입일: 09/03/21
90 평판
안내서 1개 작성함
University of Alabama, Team 1-2, Bedsole Fall 2021 University of Alabama, Team 1-2, Bedsole Fall 2021 회원
UA-BEDSOLE-F21S1G2
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 14
30일 전: 97
전체 시간: 1,693
