주요 콘텐츠로 건너뛰기
Lenovo ThinkPad X390 Yoga Speakers Replacement
필요한 것
  1. Lenovo ThinkPad X390 Yoga Speakers Replacement, Back Case: 1 단계, 이미지 1/1
    • Use a Phillips #1 screwdriver to unscrew the eight captive screws from the back of the device.
    • The screws should not be removed from the back panel, so don't try to force them out.
  2. Lenovo ThinkPad X390 Yoga Speakers Replacement: 2 단계, 이미지 1/1
    • Use the iFixit opening tool to remove the back case by entering the tip of the tool into the seam and prying up.
    • This can be tough so take your time to undo the clips around the perimeter before removing the back cover.
  3. Lenovo ThinkPad X390 Yoga Speakers Replacement: 3 단계, 이미지 1/1
    • Once the back cover is no longer attached carefully remove it by lifting straight up.
  4. Lenovo ThinkPad X390 Yoga Speakers Replacement, Battery: 4 단계, 이미지 1/1
    • Use the spudger to disconnect the battery from the motherboard at the connector socket.
  5. Lenovo ThinkPad X390 Yoga Speakers Replacement: 5 단계, 이미지 1/1
    • Use the Phillips #1 screwdriver to remove five 4 mm screws around the battery.
  6. Lenovo ThinkPad X390 Yoga Speakers Replacement: 6 단계, 이미지 1/1
    • Lift the battery out of the laptop by lifting up.
  7. Lenovo ThinkPad X390 Yoga Speakers Replacement, Speaker: 7 단계, 이미지 1/1
    • Disconnect the connector wire by gently pulling away from the port.
  8. Lenovo ThinkPad X390 Yoga Speakers Replacement: 8 단계, 이미지 1/1
    • Remove the speaker by lifting them up.
    • Gently lift the speaker cable that connects the two speakers from the perimeter of the chassis.
결론
Tanner Baine
회원 가입일: 09/03/21
423 평판
안내서 4개 작성하였습니다
University of Alabama, Team 1-2, Bedsole Fall 2021 University of Alabama, Team 1-2, Bedsole Fall 2021 회원
UA-BEDSOLE-F21S1G2
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 13
전체 시간: 367
