소개
Follow this guide to replace or upgrade the Solid State Drive (SSD) in your ThinkPad X395. Note that a thermal pad helps the SSD dissipate heat more effectively. Remember to keep the original thermal pad, or have a replacement ready.
Before you perform this repair, back up your existing SSD if possible. If you’re replacing the SSD where your operating system is installed, familiarize yourself with a disk cloning utility so you’ll be ready to migrate your data to the new SSD.
필요한 것
Use a Phillips #1 screwdriver to fully loosen the five screws on the back cover.
Orient your laptop so that the screen's silver hinges are closest to you.
Insert an opening pick between the back cover and the device body near a hinge corner.
Pry upward to release the retaining clips. Listen for a loud click when each clip releases.
Lift and remove the cover up from the laptop, starting with the edge nearest to you.
Shift the cover side to side if the center clip feels stuck.
Grab the battery pull-tab on the head of the connector.
Pull the connector out of its socket in the direction of the cable.
Use a Phillips #1 screwdriver to remove the 2.8 mm-long screw holding the SSD in place.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Lenovo ThinkPad answers community for help.
다른 한 분이 해당 안내서를 완성하였습니다.
