주요 콘텐츠로 건너뛰기
Lenovo ThinkPad X61 Battery Replacement
필요한 것
  1. Lenovo ThinkPad X61 Battery Replacement, Battery: 1 단계, 이미지 1/1
    • The first step to replacing your insufficient battery is to flip your device to the back side, with the battery on top.
    • You should then find the battery lock release located in the top left corner, as indicated in the image.
  2. Lenovo ThinkPad X61 Battery Replacement: 2 단계, 이미지 1/1
    • The next step is to simply move the switch from the locked position to the unlocked position.
  3. Lenovo ThinkPad X61 Battery Replacement: 3 단계, 이미지 1/1
    • Next, you find the second lock release switch located under the bottom right of the battery holder as marked in the image.
    • Simply move the switch over from the locked position to the unlocked position and pull the battery from its holder. You can now insert the new battery.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Ryan McCarthy
회원 가입일: 03/15/18
772 평판
안내서 4개 작성하였습니다
UMass Dartmouth, Team S8-G2, Valliere Spring 2018 UMass Dartmouth, Team S8-G2, Valliere Spring 2018 회원
UMASSD-VALLIERE-S18S8G2
2 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 7
30일 전: 26
전체 시간: 1,181
