주요 콘텐츠로 건너뛰기
Lenovo ThinkPad Yoga 11e (Gen 5) Battery Replacement
필요한 것
  1. Lenovo ThinkPad Yoga 11e (Gen 5) Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Start by putting on your anti static wrist strap and connecting it to a stationary and stable object, like a desk.
    • This safety strap serves as a precaution to prevent any electrical static you might have on your body from transferring to the laptop's internal components and damaging the hardware.
    • Reminder to have this safety strap on you at all times during the process
  2. Lenovo ThinkPad Yoga 11e (Gen 5) Battery Replacement: 2 단계, 이미지 1/3 Lenovo ThinkPad Yoga 11e (Gen 5) Battery Replacement: 2 단계, 이미지 2/3 Lenovo ThinkPad Yoga 11e (Gen 5) Battery Replacement: 2 단계, 이미지 3/3
    • Use a T5 Torx screwdriver to loosen and remove all eight bottom cover screws.
    • If you're having issues removing the bottom cover, be sure to use the opening pick to pry the case open carefully.
  3. Lenovo ThinkPad Yoga 11e (Gen 5) Battery Replacement: 3 단계, 이미지 1/2 Lenovo ThinkPad Yoga 11e (Gen 5) Battery Replacement: 3 단계, 이미지 2/2
    • Unplug the battery from the motherboard. This will need to be done before removing the battery screws.
    • The connection point is shown circled in yellow.
    • Pull the strip out, it might require some force and wiggling.
  4. Lenovo ThinkPad Yoga 11e (Gen 5) Battery Replacement: 4 단계, 이미지 1/2 Lenovo ThinkPad Yoga 11e (Gen 5) Battery Replacement: 4 단계, 이미지 2/2
    • Remove the screws holding the battery in place. There are 5 screws that need to be removed.
    • Using the same screwdriver and bit as before, remove all the screws and keep them somewhere safe.
  5. Lenovo ThinkPad Yoga 11e (Gen 5) Battery Replacement: 5 단계, 이미지 1/1
    • Remove the battery
    • The battery is latched on so it will require some force to pop it out.
결론
David Beltran Heredia
회원 가입일: 02/02/24
229 평판
안내서 2개 작성하였습니다
Gateway, Team 11-11, Gonzalez Spring 2024 Gateway, Team 11-11, Gonzalez Spring 2024 회원
GCC-GONZALEZ-S24S11G11
4 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 28
전체 시간: 85
