주요 콘텐츠로 건너뛰기
Lenovo ThinkPad Yoga 11e (Gen 5) LCD Replacement
필요한 것
  1. Lenovo ThinkPad Yoga 11e (Gen 5) LCD Replacement, LCD: 1 단계, 이미지 1/1
    • Start by putting on your anti static wrist strap and connecting it to a stationary and stable object, like a desk.
    • This safety strap serves as a precaution to prevent any electrical static you might have on your body from transferring to the laptop's internal components and damaging the hardware.
    • Reminder to have this safety strap on you at all times during the process
  2. Lenovo ThinkPad Yoga 11e (Gen 5) LCD Replacement: 2 단계, 이미지 1/2 Lenovo ThinkPad Yoga 11e (Gen 5) LCD Replacement: 2 단계, 이미지 2/2
    • Use a T5 screwdriver to remove the two 7.62 mm screws circled in red at the bottom of the front of the display.
  3. Lenovo ThinkPad Yoga 11e (Gen 5) LCD Replacement: 3 단계, 이미지 1/3 Lenovo ThinkPad Yoga 11e (Gen 5) LCD Replacement: 3 단계, 이미지 2/3 Lenovo ThinkPad Yoga 11e (Gen 5) LCD Replacement: 3 단계, 이미지 3/3
    • Heat up the iopener and apply it to all 4 edges of the display
    • Be cautious when handling the iopener as the contents are hot and follow the instructions written on the product.
    • You might need to heat up the iopener multiple times to melt the glue holding the dsoplay in place
  4. Lenovo ThinkPad Yoga 11e (Gen 5) LCD Replacement: 4 단계, 이미지 1/2 Lenovo ThinkPad Yoga 11e (Gen 5) LCD Replacement: 4 단계, 이미지 2/2
    • Use the Jimmy pick knife to pry the display open all around.
  5. Lenovo ThinkPad Yoga 11e (Gen 5) LCD Replacement: 5 단계, 이미지 1/3 Lenovo ThinkPad Yoga 11e (Gen 5) LCD Replacement: 5 단계, 이미지 2/3 Lenovo ThinkPad Yoga 11e (Gen 5) LCD Replacement: 5 단계, 이미지 3/3
    • Finally, unplug the 2 connection points of the display from the motherboard.
    • The big port will have a silver latch that needs to be flipped up for the port to come out.
    • You can now replace the old display with the new one.
결론
Onel
회원 가입일: 02/04/24
173 평판
안내서 1개 작성함
Gateway, Team 11-11, Gonzalez Spring 2024 Gateway, Team 11-11, Gonzalez Spring 2024 회원
GCC-GONZALEZ-S24S11G11
4 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 16
전체 시간: 27
