주요 콘텐츠로 건너뛰기
Lenovo ThinkPad Yoga 11e (Gen 5) SSD Replacement
필요한 것
  1. Lenovo ThinkPad Yoga 11e (Gen 5) SSD Replacement, SSD: 1 단계, 이미지 1/1
    • Start by putting on your anti static wrist strap and connecting it to a stationary and stable object, like a desk.
    • This safety strap serves as a precaution to prevent any electrical static you might have on your body from transferring to the laptop's internal components and damaging the hardware.
    • Reminder to have this safety strap on you at all times during the process
  2. Lenovo ThinkPad Yoga 11e (Gen 5) SSD Replacement: 2 단계, 이미지 1/3 Lenovo ThinkPad Yoga 11e (Gen 5) SSD Replacement: 2 단계, 이미지 2/3 Lenovo ThinkPad Yoga 11e (Gen 5) SSD Replacement: 2 단계, 이미지 3/3
    • Use a T5 Torx screwdriver to loosen and remove all eight bottom cover screws.
    • If you're having issues removing the back cover of the case, be sure to use the opening pick to pry the case open carefully.
  3. Lenovo ThinkPad Yoga 11e (Gen 5) SSD Replacement: 3 단계, 이미지 1/2 Lenovo ThinkPad Yoga 11e (Gen 5) SSD Replacement: 3 단계, 이미지 2/2
    • Locate the SSD on your device and remove the 2.3 mm screw using a Phillips #00 screwdriver.
    • Place the loose screw somewhere safe and store for reassembly.
  4. Lenovo ThinkPad Yoga 11e (Gen 5) SSD Replacement: 4 단계, 이미지 1/3 Lenovo ThinkPad Yoga 11e (Gen 5) SSD Replacement: 4 단계, 이미지 2/3 Lenovo ThinkPad Yoga 11e (Gen 5) SSD Replacement: 4 단계, 이미지 3/3
    • Pull the SSD out of its slot in the motherboard. It might require to wiggle it a little.
결론
David Beltran Heredia
회원 가입일: 02/02/24
229 평판
안내서 2개 작성하였습니다
Gateway, Team 11-11, Gonzalez Spring 2024 Gateway, Team 11-11, Gonzalez Spring 2024 회원
GCC-GONZALEZ-S24S11G11
4 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 6
30일 전: 27
전체 시간: 54
