주요 콘텐츠로 건너뛰기
Lenovo ThinkPad Yoga 11e Gen 6 Motherboard Replacement
필요한 것
  1. Lenovo ThinkPad Yoga 11e Gen 6 Motherboard Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Wearing the anti-static wrist strap will prevent a static shock from damaging the components in the laptop.
    • Disconnect the laptop from power and make sure it is completely powered off.
    • Turn the laptop facing down.
    • Loosen the eight captive screws using a JIS #0 screwdriver.
    • The screws are attached to the panel and cannot be removed.
    • Use a spudger to release the tabs securing the back case and carefully remove the panel.
  2. Lenovo ThinkPad Yoga 11e Gen 6 Motherboard Replacement: 2 단계, 이미지 2개 중 1개 Lenovo ThinkPad Yoga 11e Gen 6 Motherboard Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the three 4.5 mm screws from the battery using a JIS #0 screwdriver.
    • Lift the battery, then use your fingernail to slide the connector out of its socket.
    • Remove the battery.
  3. Lenovo ThinkPad Yoga 11e Gen 6 Motherboard Replacement, Wi-Fi Board: 3 단계, 이미지 2개 중 1개 Lenovo ThinkPad Yoga 11e Gen 6 Motherboard Replacement, Wi-Fi Board: 3 단계, 이미지 2개 중 2개
    • Push on alternating sides of the JST connector and pull straight away from the socket to disconnect the CMOS battery.
  4. Lenovo ThinkPad Yoga 11e Gen 6 Motherboard Replacement: 4 단계, 이미지 3개 중 1개 Lenovo ThinkPad Yoga 11e Gen 6 Motherboard Replacement: 4 단계, 이미지 3개 중 2개 Lenovo ThinkPad Yoga 11e Gen 6 Motherboard Replacement: 4 단계, 이미지 3개 중 3개
    • Lift the two wires and plastic piece away from the Wi-Fi board.
    • Remove the single 3 mm screw holding the Wi-Fi board in place using a Phillips #0 screwdriver.
    • Hold the sides of the Wi-Fi board and slide it out of the socket.
  5. Lenovo ThinkPad Yoga 11e Gen 6 Motherboard Replacement, Motherboard: 5 단계, 이미지 3개 중 1개 Lenovo ThinkPad Yoga 11e Gen 6 Motherboard Replacement, Motherboard: 5 단계, 이미지 3개 중 2개 Lenovo ThinkPad Yoga 11e Gen 6 Motherboard Replacement, Motherboard: 5 단계, 이미지 3개 중 3개
    • Loosen the four captive screws from the metal panel with a copper strip on it using a Phillips #0 screwdriver.
    • Carefully lift the metal panel. The screws are attached to the panel and will not come out.
  6. Lenovo ThinkPad Yoga 11e Gen 6 Motherboard Replacement: 6 단계, 이미지 3개 중 1개 Lenovo ThinkPad Yoga 11e Gen 6 Motherboard Replacement: 6 단계, 이미지 3개 중 2개 Lenovo ThinkPad Yoga 11e Gen 6 Motherboard Replacement: 6 단계, 이미지 3개 중 3개
    • Pinch one of the display cable connectors and gently pull it out of its socket. Do the same for the 2nd display cable connector.
    • Pinch the sliding connector and slide it out.
    • Remove the 3 No-Fuss Ribbon Cable Connectors by pulling them out.
  7. Lenovo ThinkPad Yoga 11e Gen 6 Motherboard Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the three 4.5mm screws using a Phillips #0 screwdriver.
  8. Lenovo ThinkPad Yoga 11e Gen 6 Motherboard Replacement: 8 단계, 이미지 1개 중 1개
    • Gently lift and remove the motherboard out from the laptop.
결론
작성자
4다른 기여자 명과 함께
Lex
회원 가입일: 10/02/24
515 평판
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 11
지난 30일: 44
전체 시간: 514
