주요 콘텐츠로 건너뛰기
Lenovo ThinkPad Yoga 14 20FY Keyboard Replacement
필요한 것
  1. Lenovo ThinkPad Yoga 14 20FY Keyboard Replacement, Keyboard: 1 단계, 이미지 1/1
    • Unplug and completely shut down your computer beforehand to reduce the risk of electric shock.
    • Flip the laptop over so you can see the bottom panel.
    • Unscrew the circled screws to detach the keyboard.
  2. Lenovo ThinkPad Yoga 14 20FY Keyboard Replacement: 2 단계, 이미지 1/3 Lenovo ThinkPad Yoga 14 20FY Keyboard Replacement: 2 단계, 이미지 2/3 Lenovo ThinkPad Yoga 14 20FY Keyboard Replacement: 2 단계, 이미지 3/3
    • Flip the laptop back over and open it normally.
    • Use a plastic opening tool to lift up the keyboard along the bottom edge until it is detached.
  3. Lenovo ThinkPad Yoga 14 20FY Keyboard Replacement: 3 단계, 이미지 1/2 Lenovo ThinkPad Yoga 14 20FY Keyboard Replacement: 3 단계, 이미지 2/2
    • Using a finger, push the top of the keyboard out of its holder to completely detach it.
    • Move the keyboard out of the way by rotating the far side of the keyboard towards you.
  4. Lenovo ThinkPad Yoga 14 20FY Keyboard Replacement: 4 단계, 이미지 1/2 Lenovo ThinkPad Yoga 14 20FY Keyboard Replacement: 4 단계, 이미지 2/2
    • Be gentle! These connectors are very small and can easily break off.
    • Lay the keyboard on its front.
    • Disconnect the 3 cables by pulling on the attached tabs.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Sarthak Khillon
회원 가입일: 04/12/17
259 평판
안내서 1개 작성함
Cal Poly, Team S14-G2, Banghart Spring 2017 Cal Poly, Team S14-G2, Banghart Spring 2017 회원
CPSU-BANGHART-S17S14G2
5 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 23
전체 시간: 5,564
