주요 콘텐츠로 건너뛰기
Lenovo ThinkPad Yoga 260 Motherboard Replacement
필요한 것
  1. Lenovo ThinkPad Yoga 260 Motherboard Replacement, Back Cover: 1 단계, 이미지 1/1
    • Ensure the device is off and unplugged.
    • Remove the stylus from its port and set aside.
  2. Lenovo ThinkPad Yoga 260 Motherboard Replacement: 2 단계, 이미지 1/2 Lenovo ThinkPad Yoga 260 Motherboard Replacement: 2 단계, 이미지 2/2
    • Using a Phillips #1 screwdriver, gently unscrew the eight 1.3 mm Phillips #1 screws until you hear an audible click.
    • The screws will not separate from the bottom cover when loose.
  3. Lenovo ThinkPad Yoga 260 Motherboard Replacement: 3 단계, 이미지 1/2 Lenovo ThinkPad Yoga 260 Motherboard Replacement: 3 단계, 이미지 2/2
    • The bottom cover is attached via several plastic clips located around the edges of the bottom cover.
    • Using a plastic opening tool, gently pry the bottom cover from the laptop.
    • Work the plastic opening tool around the edges of the bottom cover undoing all of the plastic clips, as shown in the picture.
  4. Lenovo ThinkPad Yoga 260 Motherboard Replacement: 4 단계, 이미지 1/2 Lenovo ThinkPad Yoga 260 Motherboard Replacement: 4 단계, 이미지 2/2
    • Place your fingers around the edges of the cover and remove it.
  5. Lenovo ThinkPad Yoga 260 Motherboard Replacement, Battery: 5 단계, 이미지 1/3 Lenovo ThinkPad Yoga 260 Motherboard Replacement, Battery: 5 단계, 이미지 2/3 Lenovo ThinkPad Yoga 260 Motherboard Replacement, Battery: 5 단계, 이미지 3/3
    • Fold back the plastic cover to access the battery connection.
    • Remove the battery connection using your two index fingers.
    • Gently separate the connectors.
  6. Lenovo ThinkPad Yoga 260 Motherboard Replacement: 6 단계, 이미지 1/3 Lenovo ThinkPad Yoga 260 Motherboard Replacement: 6 단계, 이미지 2/3 Lenovo ThinkPad Yoga 260 Motherboard Replacement: 6 단계, 이미지 3/3
    • Unscrew the two 1.3 mm Phillips #1 fasteners using a Phillips #1 screwdriver and set them aside.
    • Lift the battery free from its mounting and remove it.
  7. Lenovo ThinkPad Yoga 260 Motherboard Replacement, RAM: 7 단계, 이미지 1/2 Lenovo ThinkPad Yoga 260 Motherboard Replacement, RAM: 7 단계, 이미지 2/2
    • Using both thumbs, pinch the RAM's mounting clips outward.
    • The RAM module will spring up on its own.
  8. Lenovo ThinkPad Yoga 260 Motherboard Replacement: 8 단계, 이미지 1/1
    • Gently remove it from its mounting.
  9. Lenovo ThinkPad Yoga 260 Motherboard Replacement, Heat Sink: 9 단계, 이미지 1/2 Lenovo ThinkPad Yoga 260 Motherboard Replacement, Heat Sink: 9 단계, 이미지 2/2
    • Heatsink should be cool to the touch.
    • Using your index fingers, gently remove the fan’s power connection.
  10. Lenovo ThinkPad Yoga 260 Motherboard Replacement: 10 단계, 이미지 1/2 Lenovo ThinkPad Yoga 260 Motherboard Replacement: 10 단계, 이미지 2/2
    • Using a Phillips #1 screwdriver, remove the four 1.3 mm Phillips #1 screws and set them aside.
    • The screws will not separate from the mounting when loose.
  11. Lenovo ThinkPad Yoga 260 Motherboard Replacement: 11 단계, 이미지 1/1
    • Using your index finger and thumb, gently pry the cooler from its mountings and remove the assembly.
  12. Lenovo ThinkPad Yoga 260 Motherboard Replacement, Wifi-Card: 12 단계, 이미지 1/3 Lenovo ThinkPad Yoga 260 Motherboard Replacement, Wifi-Card: 12 단계, 이미지 2/3 Lenovo ThinkPad Yoga 260 Motherboard Replacement, Wifi-Card: 12 단계, 이미지 3/3
    • Using a Phillips #1 screwdriver, remove the 1.3 mm screw and set it aside.
  13. Lenovo ThinkPad Yoga 260 Motherboard Replacement: 13 단계, 이미지 1/2 Lenovo ThinkPad Yoga 260 Motherboard Replacement: 13 단계, 이미지 2/2
    • Carefully pull out the Wi-Fi card.
    • Be sure to pull laterally, not upwards.
  14. Lenovo ThinkPad Yoga 260 Motherboard Replacement: 14 단계, 이미지 1/2 Lenovo ThinkPad Yoga 260 Motherboard Replacement: 14 단계, 이미지 2/2
    • Carefully disconnect the 2 cables from the WiFi-Card as indicated on the card label.
    • Set the Wifi-Card aside.
  15. Lenovo ThinkPad Yoga 260 Motherboard Replacement, Motherboard: 15 단계, 이미지 1/2 Lenovo ThinkPad Yoga 260 Motherboard Replacement, Motherboard: 15 단계, 이미지 2/2
    • Disconnect the speaker cable located near hinge side of the laptop.
    • Remove both speakers from the assembly.
  16. Lenovo ThinkPad Yoga 260 Motherboard Replacement: 16 단계, 이미지 1/3 Lenovo ThinkPad Yoga 260 Motherboard Replacement: 16 단계, 이미지 2/3 Lenovo ThinkPad Yoga 260 Motherboard Replacement: 16 단계, 이미지 3/3
    • Gently lift up the SD chip's black protective film.
    • Unplug the SD chip from the assembly and set the SD chip aside.
  17. Lenovo ThinkPad Yoga 260 Motherboard Replacement: 17 단계, 이미지 1/3 Lenovo ThinkPad Yoga 260 Motherboard Replacement: 17 단계, 이미지 2/3 Lenovo ThinkPad Yoga 260 Motherboard Replacement: 17 단계, 이미지 3/3
    • Pull up on the 2 black tabs to remove the cords located along the hinge edge of the device.
  18. Lenovo ThinkPad Yoga 260 Motherboard Replacement: 18 단계, 이미지 1/3 Lenovo ThinkPad Yoga 260 Motherboard Replacement: 18 단계, 이미지 2/3 Lenovo ThinkPad Yoga 260 Motherboard Replacement: 18 단계, 이미지 3/3
    • Pull up the 6 colored tabs along the edge of the motherboard to disconnect them from the motherboard.
  19. Lenovo ThinkPad Yoga 260 Motherboard Replacement: 19 단계, 이미지 1/1
    • Remove the fourteen .8 mm screws on the motherboard using a Phillips #00 screwdriver.
    • Carefully lift the motherboard out of assembly.
    • Ensure no wires or cables remain connected.
결론
다른 5명이 해당 안내서를 완성하였습니다.
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 53
전체 시간: 2,296
