주요 콘텐츠로 건너뛰기
Lenovo ThinkPad Yoga 260 Repair Battery Replacement
필요한 것
  1. Lenovo ThinkPad Yoga 260 Repair Battery Replacement, Back Cover: 1 단계, 이미지 1/1
    • Ensure the device is off and unplugged.
    • Remove the stylus from its port and set aside.
  2. Lenovo ThinkPad Yoga 260 Repair Battery Replacement: 2 단계, 이미지 1/2 Lenovo ThinkPad Yoga 260 Repair Battery Replacement: 2 단계, 이미지 2/2
    • Using a Phillips #1 screwdriver, gently unscrew the eight 1.3 mm Phillips #1 screws until you hear an audible click.
    • The screws will not separate from the bottom cover when loose.
  3. Lenovo ThinkPad Yoga 260 Repair Battery Replacement: 3 단계, 이미지 1/2 Lenovo ThinkPad Yoga 260 Repair Battery Replacement: 3 단계, 이미지 2/2
    • The bottom cover is attached via several plastic clips located around the edges of the bottom cover.
    • Using a plastic opening tool, gently pry the bottom cover from the laptop.
    • Work the plastic opening tool around the edges of the bottom cover undoing all of the plastic clips, as shown in the picture.
  4. Lenovo ThinkPad Yoga 260 Repair Battery Replacement: 4 단계, 이미지 1/2 Lenovo ThinkPad Yoga 260 Repair Battery Replacement: 4 단계, 이미지 2/2
    • Place your fingers around the edges of the cover and remove it.
  5. Lenovo ThinkPad Yoga 260 Repair Battery Replacement, Battery: 5 단계, 이미지 1/3 Lenovo ThinkPad Yoga 260 Repair Battery Replacement, Battery: 5 단계, 이미지 2/3 Lenovo ThinkPad Yoga 260 Repair Battery Replacement, Battery: 5 단계, 이미지 3/3
    • Fold back the plastic cover to access the battery connection.
    • Remove the battery connection using your two index fingers.
    • Gently separate the connectors.
  6. Lenovo ThinkPad Yoga 260 Repair Battery Replacement: 6 단계, 이미지 1/3 Lenovo ThinkPad Yoga 260 Repair Battery Replacement: 6 단계, 이미지 2/3 Lenovo ThinkPad Yoga 260 Repair Battery Replacement: 6 단계, 이미지 3/3
    • Unscrew the two 1.3 mm Phillips #1 fasteners using a Phillips #1 screwdriver and set them aside.
    • Lift the battery free from its mounting and remove it.
결론
다른 7명이 해당 안내서를 완성하였습니다.
Daniel Fernandez
회원 가입일: 02/14/18
963 평판
안내서 5개 작성하였습니다
USF Tampa, Team S2-G3, Eyestone Spring 2018 USF Tampa, Team S2-G3, Eyestone Spring 2018 회원
USFT-EYESTONE-S18S2G3
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 10
30일 전: 47
전체 시간: 7,242
