주요 콘텐츠로 건너뛰기
Lenovo ThinkPad Yoga 260 Repair Heat Sink Replacement
필요한 것
  1. Lenovo ThinkPad Yoga 260 Repair Heat Sink Replacement, Back Cover: 1 단계, 이미지 1/1
    • Ensure the device is off and unplugged.
    • Remove the stylus from its port and set aside.
  2. Lenovo ThinkPad Yoga 260 Repair Heat Sink Replacement: 2 단계, 이미지 1/2 Lenovo ThinkPad Yoga 260 Repair Heat Sink Replacement: 2 단계, 이미지 2/2
    • Using a Phillips #1 screwdriver, gently unscrew the eight 1.3 mm Phillips #1 screws until you hear an audible click.
    • The screws will not separate from the bottom cover when loose.
  3. Lenovo ThinkPad Yoga 260 Repair Heat Sink Replacement: 3 단계, 이미지 1/2 Lenovo ThinkPad Yoga 260 Repair Heat Sink Replacement: 3 단계, 이미지 2/2
    • The bottom cover is attached via several plastic clips located around the edges of the bottom cover.
    • Using a plastic opening tool, gently pry the bottom cover from the laptop.
    • Work the plastic opening tool around the edges of the bottom cover undoing all of the plastic clips, as shown in the picture.
  4. Lenovo ThinkPad Yoga 260 Repair Heat Sink Replacement: 4 단계, 이미지 1/2 Lenovo ThinkPad Yoga 260 Repair Heat Sink Replacement: 4 단계, 이미지 2/2
    • Place your fingers around the edges of the cover and remove it.
  5. Lenovo ThinkPad Yoga 260 Repair Heat Sink Replacement, Heat Sink: 5 단계, 이미지 1/2 Lenovo ThinkPad Yoga 260 Repair Heat Sink Replacement, Heat Sink: 5 단계, 이미지 2/2
    • Heatsink should be cool to the touch.
    • Using your index fingers, gently remove the fan’s power connection.
  6. Lenovo ThinkPad Yoga 260 Repair Heat Sink Replacement: 6 단계, 이미지 1/2 Lenovo ThinkPad Yoga 260 Repair Heat Sink Replacement: 6 단계, 이미지 2/2
    • Using a Phillips #1 screwdriver, remove the four 1.3 mm Phillips #1 screws and set them aside.
    • The screws will not separate from the mounting when loose.
  7. Lenovo ThinkPad Yoga 260 Repair Heat Sink Replacement: 7 단계, 이미지 1/1
    • Using your index finger and thumb, gently pry the cooler from its mountings and remove the assembly.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Daniel Fernandez
회원 가입일: 02/14/18
963 평판
안내서 5개 작성하였습니다
USF Tampa, Team S2-G3, Eyestone Spring 2018 USF Tampa, Team S2-G3, Eyestone Spring 2018 회원
USFT-EYESTONE-S18S2G3
4 회원들
안내서 5개 작성하였습니다
댓글 한 개
Good guide, thank you. Clear and concise with very easy to follow pictures and instruction. As usual, iFixit to the rescue :-)
Mark Taylor (wodin69) - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 12
전체 시간: 1,201
