주요 콘텐츠로 건너뛰기
Lenovo ThinkPad Yoga 260 Wifi-Card Replacement
필요한 것
  1. Lenovo ThinkPad Yoga 260 Wifi-Card Replacement, Back Cover: 1 단계, 이미지 1/1
    • Ensure the device is off and unplugged.
    • Remove the stylus from its port and set aside.
  2. Lenovo ThinkPad Yoga 260 Wifi-Card Replacement: 2 단계, 이미지 1/2 Lenovo ThinkPad Yoga 260 Wifi-Card Replacement: 2 단계, 이미지 2/2
    • Using a Phillips #1 screwdriver, gently unscrew the eight 1.3 mm Phillips #1 screws until you hear an audible click.
    • The screws will not separate from the bottom cover when loose.
  3. Lenovo ThinkPad Yoga 260 Wifi-Card Replacement: 3 단계, 이미지 1/2 Lenovo ThinkPad Yoga 260 Wifi-Card Replacement: 3 단계, 이미지 2/2
    • The bottom cover is attached via several plastic clips located around the edges of the bottom cover.
    • Using a plastic opening tool, gently pry the bottom cover from the laptop.
    • Work the plastic opening tool around the edges of the bottom cover undoing all of the plastic clips, as shown in the picture.
  4. Lenovo ThinkPad Yoga 260 Wifi-Card Replacement: 4 단계, 이미지 1/2 Lenovo ThinkPad Yoga 260 Wifi-Card Replacement: 4 단계, 이미지 2/2
    • Place your fingers around the edges of the cover and remove it.
  5. Lenovo ThinkPad Yoga 260 Wifi-Card Replacement, Wifi-Card: 5 단계, 이미지 1/3 Lenovo ThinkPad Yoga 260 Wifi-Card Replacement, Wifi-Card: 5 단계, 이미지 2/3 Lenovo ThinkPad Yoga 260 Wifi-Card Replacement, Wifi-Card: 5 단계, 이미지 3/3
    • Using a Phillips #1 screwdriver, remove the 1.3 mm screw and set it aside.
  6. Lenovo ThinkPad Yoga 260 Wifi-Card Replacement: 6 단계, 이미지 1/2 Lenovo ThinkPad Yoga 260 Wifi-Card Replacement: 6 단계, 이미지 2/2
    • Carefully pull out the Wi-Fi card.
    • Be sure to pull laterally, not upwards.
  7. Lenovo ThinkPad Yoga 260 Wifi-Card Replacement: 7 단계, 이미지 1/2 Lenovo ThinkPad Yoga 260 Wifi-Card Replacement: 7 단계, 이미지 2/2
    • Carefully disconnect the 2 cables from the WiFi-Card as indicated on the card label.
    • Set the Wifi-Card aside.
결론
다른 3명이 해당 안내서를 완성하였습니다.
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 27
전체 시간: 905
