소개
If the Wifi-card for your Lenovo Thinkpad Yoga 260 (Model Number: 20FD002HUS) is defective or broken, this guide will carefully walk you through the steps to replace it.
A damaged or faulty Wifi-card can lead to an unstable network connection or none at all. If you are experiencing intermittent wireless connections or your device is failing to detect wireless signals you may consider replacing your Wifi-card.
Before using this guide ensure the laptop is powered off, disconnected from external power sources, and you have the listed tools available for use.
필요한 것
다른 3명이 해당 안내서를 완성하였습니다.
