주요 콘텐츠로 건너뛰기
Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement
필요한 것
  1. Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Device needs to be powered off and unplugged.
    • Remove the stylus from the device and set it aside.
  2. Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: 2 단계, 이미지 2개 중 1개 Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: 2 단계, 이미지 2개 중 2개
    • Using the Phillips #00 screwdriver unscrew the eight circled 4mm screws until you hear a click.
    • The screws will remain attached to the back cover.
  3. Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: 3 단계, 이미지 2개 중 1개 Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: 3 단계, 이미지 2개 중 2개
    • Note that while the screws are undone, the bottom cover is still attached by several plastic clips around the edges.
    • Using the plastic opening tool, work around the edges of the bottom cover to undo the plastic clips.
  4. Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: 4 단계, 이미지 2개 중 1개 Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: 4 단계, 이미지 2개 중 2개
    • Gently remove the cover by placing your fingers around the edges.
  5. Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: 5 단계, 이미지 3개 중 1개 Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: 5 단계, 이미지 3개 중 2개 Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: 5 단계, 이미지 3개 중 3개
    • With your fingers, fold back the plastic cover highlighted.
    • Using two fingers, gently remove the battery connectors.
  6. Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: 6 단계, 이미지 3개 중 1개 Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: 6 단계, 이미지 3개 중 2개 Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: 6 단계, 이미지 3개 중 3개
    • Using the Phillips #00 screwdriver, remove the two 4mm screws.
    • Remove the battery.
    • Make sure to only replace with a battery that matches your computer, any other battery could ignite or explode.
  7. Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement, Fingerprint Reader: 7 단계, 이미지 1개 중 1개
    • Identify the fingerprint reader on the left side of the laptop.
  8. Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: 8 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • To disconnect the fingerprint reader from the motherboard, unlock the ZIF connector and pull it out using tweezers.
  9. Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: 9 단계, 이미지 2개 중 1개 Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: 9 단계, 이미지 2개 중 2개
    • Remove the one 4 mm screw from the metal covering with the Phillips #00 screwdriver.
    • Remove the metal cover.
  10. Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: 10 단계, 이미지 1개 중 1개
    • Using tweezers, remove the fingerprint reader from the inset.
결론
작성자
3다른 기여자 명과 함께
Jakobe Denby
회원 가입일: 01/18/22
112 평판
안내서 1개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 19
전체 시간: 461
