주요 콘텐츠로 건너뛰기
Lenovo ThinkPad Yoga 370 Hard Drive Replacement
필요한 것
  1. Lenovo ThinkPad Yoga 370 Hard Drive Replacement, Hard Drive: 1 단계, 이미지 1개 중 1개
    • Device needs to be powered off and unplugged.
    • Remove the stylus from the device and set aside.
  2. Lenovo ThinkPad Yoga 370 Hard Drive Replacement: 2 단계, 이미지 2개 중 1개 Lenovo ThinkPad Yoga 370 Hard Drive Replacement: 2 단계, 이미지 2개 중 2개
    • Using the Phillips #00 screwdriver, unscrew the eight circled 4mm screws until you hear a click.
    • The screws will remain attached to the back cover.
  3. Lenovo ThinkPad Yoga 370 Hard Drive Replacement: 3 단계, 이미지 2개 중 1개 Lenovo ThinkPad Yoga 370 Hard Drive Replacement: 3 단계, 이미지 2개 중 2개
    • Note that while the screws are undone, the bottom cover is still attached by several plastic clips around the edges.
    • Using the plastic opening tool, work around the edges of the bottom cover to undo the plastic clips.
  4. Lenovo ThinkPad Yoga 370 Hard Drive Replacement: 4 단계, 이미지 2개 중 1개 Lenovo ThinkPad Yoga 370 Hard Drive Replacement: 4 단계, 이미지 2개 중 2개
    • Gently remove the cover by placing your fingers around the edges.
  5. Lenovo ThinkPad Yoga 370 Hard Drive Replacement: 5 단계, 이미지 3개 중 1개 Lenovo ThinkPad Yoga 370 Hard Drive Replacement: 5 단계, 이미지 3개 중 2개 Lenovo ThinkPad Yoga 370 Hard Drive Replacement: 5 단계, 이미지 3개 중 3개
    • Gently pull back the heat shield on the hard drive without tearing it or completely removing it.
  6. Lenovo ThinkPad Yoga 370 Hard Drive Replacement: 6 단계, 이미지 1개 중 1개
    • Using the Phillips #00 screwdriver, remove the 5mm screw and set aside.
  7. Lenovo ThinkPad Yoga 370 Hard Drive Replacement: 7 단계, 이미지 1개 중 1개
    • Using two fingers, gently pull the hard drive straight out of the connection to remove it from device.
결론
Note: Due to the similarity of the devices, several of the pictures were used from the Lenovo ThinkPad Yoga 260 Battery Replacement Guide to show the specific components that were missing in the Yoga 370.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Cassandra Shedden
회원 가입일: 09/17/19
1,131 평판
안내서 5개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 12
지난 30일: 43
전체 시간: 3,705
