주요 콘텐츠로 건너뛰기
Lenovo ThinkPad Yoga 370 RAM Replacement
필요한 것
  1. Lenovo ThinkPad Yoga 370 RAM Replacement, RAM: 1 단계, 이미지 1/1
    • Device needs to be powered off and unplugged.
    • Remove the stylus from the device and set it aside.
  2. Lenovo ThinkPad Yoga 370 RAM Replacement: 2 단계, 이미지 1/2 Lenovo ThinkPad Yoga 370 RAM Replacement: 2 단계, 이미지 2/2
    • Using the Phillips #00 screwdriver, unscrew the eight circled 4mm screws until you hear a click.
    • The screws will remain attached to the back cover.
  3. Lenovo ThinkPad Yoga 370 RAM Replacement: 3 단계, 이미지 1/2 Lenovo ThinkPad Yoga 370 RAM Replacement: 3 단계, 이미지 2/2
    • Note that while the screws are undone, the bottom cover is still attached by several plastic clips around the edges.
    • Using the plastic opening tool, work around the edges of the bottom cover to undo the plastic clips.
  4. Lenovo ThinkPad Yoga 370 RAM Replacement: 4 단계, 이미지 1/2 Lenovo ThinkPad Yoga 370 RAM Replacement: 4 단계, 이미지 2/2
    • Gently remove the cover by placing your fingers around the edges.
  5. Lenovo ThinkPad Yoga 370 RAM Replacement: 5 단계, 이미지 1/2 Lenovo ThinkPad Yoga 370 RAM Replacement: 5 단계, 이미지 2/2
    • Using your thumbs, push the RAM's mounting clips outward.
    • The module will pop up on its own.
  6. Lenovo ThinkPad Yoga 370 RAM Replacement: 6 단계, 이미지 1/1
    • Gently remove the RAM from the mounting.
결론
Note: Due to the similarity of the devices, several of the pictures were used from the Lenovo ThinkPad Yoga 260 Battery Replacement Guide to show the specific components that were missing in the Yoga 370.
다른 4명이 해당 안내서를 완성하였습니다.
Cassandra Shedden
회원 가입일: 09/17/19
1,077 평판
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 11
30일 전: 83
전체 시간: 6,120
