주요 콘텐츠로 건너뛰기
Lenovo ThinkPad Yoga 370 Screen Replacement
필요한 것
  1. Lenovo ThinkPad Yoga 370 Screen Replacement, Screen: 1 단계, 이미지 1/1
    • Remove rubber plugs on the lower corners of the screen
    • Unscrew screws under the rubber plugs
  2. Lenovo ThinkPad Yoga 370 Screen Replacement: 2 단계, 이미지 1/2 Lenovo ThinkPad Yoga 370 Screen Replacement: 2 단계, 이미지 2/2
    • Remove the four 4 mm screws along the bottom of the display.
  3. Lenovo ThinkPad Yoga 370 Screen Replacement: 3 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Using tweezers, remove the tape from the display cable below the screen.
  4. Lenovo ThinkPad Yoga 370 Screen Replacement: 4 단계, 이미지 1/1
    • Slide the screen downwards towards the keyboard.
    • Lift the screen slowly from the frame when the screen is slid down completely.
    • The screen is still attached to the computer, do not pull away from the laptop frame until a later step.
    • Flip the screen over and lay face down on the keyboard.
  5. Lenovo ThinkPad Yoga 370 Screen Replacement: 5 단계, 이미지 1/3 Lenovo ThinkPad Yoga 370 Screen Replacement: 5 단계, 이미지 2/3 Lenovo ThinkPad Yoga 370 Screen Replacement: 5 단계, 이미지 3/3
    • Peel the tape off from the back of the screen, connecting the display to the device.
    • Remove the screen.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Chenoa Begaye
회원 가입일: 01/18/22
136 평판
안내서 1개 작성함
댓글 한 개
I strongly recommend to at least unplug the battery before replacing the screen. I fried a motherboard once by manipulating a screen ribbon while the battery was still plugged in.
You should always unplug the battery before working on a device anyway.
lululock - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 20
30일 전: 66
전체 시간: 2,344
